HS4 Release Announcements 4.2.16.0 is available!
This is a sticky topic.
    HS4 release 4.2.16.0 is now available!
    • This build has a fix for the Chrome issue where plugin triggers cannot be configured.
    Update through setup or see the release notes for download links.
    Release notes and download links:
    https://docs.homeseer.com/display/HS...elease+4.2.16.0
    If you are testing our latest HSTouch Designer refresh, please make sure you update to build 4.2.14.0 or later as it has some changes that are needed for some of the new HSTouch features.
    HSTouch Designer - HomeSeer Message Board
    I see there is still the old 15 tarfile for the Linux distribution onder the 'Download HS4 Linux'.
      For the moment use: https://homeseer.com/updates4/linux_4_2_16_0.tar.gz
      Jon
        Thanks for the quick help!
          Thanks, link is fixed.
            Not sure this is related to .16 but I have an EasyTrigger have an update waiting and I can't get the update to proceed.
            When I press the cloud, the complete Homeseer window becomes grey-ish but the window to start the update does not show so impossible to complete the update process.
            running HS4 in Chrome Version 105.0.5195.102
            Click image for larger version  Name:	aaa.jpg Views:	0 Size:	37.5 KB ID:	1566414
            Date/time=2022-09-15 16:43:07 Est (heure d’été)
            Version=HS4 Pro Edition 4.2.16.0 (Windows)
            License=Registered
            Confguration File=C:\Program Files (x86)\HomeSeer HS4\Data\HomeSeerData.json
            In Virtual Machine=No MFG: hp
            Antivirus=Windows Defender
            OS=Microsoft Windows 10 Famille - Work Station
            OS Version=10.0.19044
            Uptime=0 Days 0 Hours 6 Minutes 30 Seconds
            Lan IP=192.168.1.70 (serveur-2)
            Device Count=1095
            Event Count=304
            Processor:=Intel64 Family 6 Model 158 Stepping 10 at 2,97 GHz
            Modules/Threads=163 Modules, 141 Threads
            Available Threads=1023
            System Load=218 Processes, 3% Load
            Free/Total Memory=41,42 GBytes / 47,87 GBytes (87% free)
            Free/Total Virtual Memory=47,55 GBytes / 54,87 GBytes (87% free)
            HomeSeer Memory Used=176 Mbytes
            Plugin Memory Used=14 EXE Plug-Ins using 636 Mbytes
            Plugins Installed=BLBackup 2.0.63.0,Blue-Iris 3.1.3.33206,Device History 3.3.1.0,EasyTrigger 3.0.0.75,EnvCan 3.0.0.18,EnvisaLink 3.0.0.42,Harmony Hub 4.0.13.0,Honeywell WiFi Thermostat 1.4.2.2,mcsMQTT 5.26.5.4,MeiKu 3.2.0.10,Pushover 4.0.8.0,Restart 1.0.0.7,Sonos4 4.0.1.12,UltraLog3 3.0.6644.26753,Unifi 4.0.25.0,Z-Wave 3.0.10.0,Z-Wave UI 1.0.0.0
              I had the same thing happen. Just exit out and "add" the ET plugin (again) instead of updating it. The re-add will update. Report back here.
                Same thing, and avpman solution does indeed work. Just remember to choose the beta version.
                RJ_Make On YouTube
                  good catch, this fixed the problem, thanks
                      Anyone with a slow event page try this?
                      Plug-Ins Enabled:
                        rjh
                        I have a Feature Request,
                        Is it possible to add native operators for multiplying and dividing the value of a feature.
                        This will limit the number of virtual devices to be created.
                        John
                          Can you give me an example as to how this would work and where you would use it?
                          Originally posted by John245 View Post
                          rjh
                          John
                            For e.g. I have a Z-wave device which measure the voltage signal. A pressure sensor (0-10V) is connected to this device and the range of the pressure sensor is 0 - 1 bar. So I need to divide by 10 to get the result in bars or multiply with 100 to get the result in mbar.
                            I suggest to add an operator selector and a possibility to enter the factor to the range options. For the operator selector I suggest to include at least a divider and a multiplier as operator and a default value of "n/a"/
                            I'm aware that there are workarounds. But a native solution will make the product more user friendly.
Name:	Capture feature mbar.png
                            Figure 1: feature
Name:	Capture rang options.png
                            Figure 2: range options
                            John
                              Do you mean generally upgrading to 4.2.1.16.0? If so, yeah, I have and my events page still takes 20 seconds to load every time.
