HS4 keeps locking up. Help needed.
    For a good while now. I find homeseer has locked up. I cannot access the webpages locally or from another computer via the url.
    If I open the log files via the .hsd file, I can see some thing are still working, but everything relating to the web service has stopped.
    I have to shutdown (which doesn’t always shut down) - if not kill the app.
    then I relaunch and it works for a while then hangs again.
    it has now seemed to do this very frequently. It doesn’t stay up long at all.
    Any ideas please?
    Check your Windows Event Viewer for any clues around the time that it hung.
    67 Z-Wave Nodes, 111 Events, 422 Devices
    Z-Wave, UPB, WiFi
    Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
      I know this isn't a solution, but how long did you wait for the URL to update? I've had this happen before when my log file got really large. It would take over 1 minute to update each page refresh.
      EDIT: Is this Windows or Linux? Check "task Manage" or "top" to see if there's any clues there.
        It is windows. Task manager seems fine, Nothing being strained at all.
        Any page you go to in Homeseer just sits there spinning in the browser.
        Eventually i just shut Homeseer then relaunch it and everything works again (for a period of time)
        Any ideas?
          Try retrieving the log at the point where it’s slowing down. Also check the log size. When you next restart HS4 disable logging and allow HS4 to run to see if it is still locking up.
            Any ideas?
            This happens more times to me than I'd like and I'm on a Linux system. Go to a new page and the browser just sits there with the whirley circle. You can even see it happen on some HowTos on YouTube. The solution to the YouTube folks and for me has been to hit the page refresh button.
              Ditto hanging issue for me regarding a Hs4-pi that is 800 miles a way. The UI is dead while events appear to continue to function normally. I typically restart homeseer or easier to just reboot the rasbpi via ssh.
              Problem exists across multiple hs4 upgrades. Planning to replace the sd card when I am back onsite.
                I suspect the issue was I had some zwave devices reporting back way to often and causing a big queue. (I had a couple of plugs reporting back the watts/amps etc way to frequently.
                How can i see the status of the ZWave network in HS4? I cant find anything
                  In the older versions of the plugin, there was a screen that shows the input/output queue. I dont see anything in the v4.x version of the plugin.
                  Z-Wave, UPB, WiFi
                    Yet another reason to my list of "How can they call HS4 an upgrade to HS3" !!
                      HS4 and the 4.x Z-Wave plugin aren't the same thing. Yes, the "4" is confusing.
