Please bring back an HS3-type compact device listing. Excel style. The HS4 interface is painful. The custom CSS offered to correct this did nothing more than I could already do by scaling my browser window. Thanks!
HS4 Feature Poll (Pick 5 features)
Originally posted by rjh View PostAmazon devices are so cheap and work well that why not use one of those? I have both in my home but use the Echo devices more often.
Originally posted by rjh View PostWe can look more into #2, I have not looked into that yet. However, you can use the mic icon in HSMobile to give voice commands and that does not use the cloud, its all local. Same with the HSTouch client app.
Karl S
HS4Pro on Windows 10
1070 Devices
56 Z-Wave Nodes
104 Events
HSTouch Clients: 3 Android, 1 iOS
Google Home: 3 Mini units, 1 Pair Audios, 2 Displays
I didn't expect a reply. Thank you very much! I just wanted to comment on a few things.
Originally posted by rjh View PostThe "Tell HomeSeer" skill still available with Amazon. Look for the skill named "HomeSeer Home Automation Skill". This simply sends the raw text that was heard to HS. You can do whatever you want with the text including parsing it yourself with a script.
Originally posted by rjh View PostHowever, you can use the mic icon in HSMobile to give voice commands and that does not use the cloud, its all local. Same with the HSTouch client app.
That might be a feature you could look into incorporating into your mobile apps. A shortcut or widget that instantly listens and fires off a voice command.
That said, my requests here are all focused on the Google smart speaker/display experience. Not having to grab your phone is one of the key benefits of smart speakers and displays. And keeping communications local could only improve that experience, plus add to your "doesn't need the cloud" marketing. Anyway, I'm very glad to hear you'll look into #2! I hope it offers what I think it does.
To sum up, I would at least like to see Google integration match that of Amazon integration. Additionally, it looks like there may be an opportunity for Google integration to surpass Amazon integration.
No need to comment on my latest comments. I appreciate you guys listening!
Edit: Ouch, I guess the Nest Mini isn't so cheap anymore at $49. I seem to remember the first generation were $29. Even then I never paid full price for any of my Google speakers or displays. I always caught them in packages or other sales. I even got a couple free because my girlfriend and I are Google Fi customers!HS4, Insteon, Z-wave, USB-UIRT, Harmony Hubs, Google Hub/Chromecasts/Speakers, Foscam & Amcrest cameras, EZVIZ DB1 doorbell
Plugins: BLLAN, BLOccupied, BLUSBUIRT, Chromecast, Harmony Hub, Insteon, Jon00 Homeseer/Echo Skill Helper, Harmony Hub, Jon00 DB Charting, MediaController, NetCAM, PHLocation2, Pushover 3P, weatherXML, Z-wave
Originally posted by PaulB View PostIs there any plugin for Apple Siri or homekit?
https://forums.homeseer.com/forum/ho...meseer4-plugin
https://github.com/jvmahon/Homebridge-HomeSeer4HS4 Pro on Shuttle NC10U, Win10; Z-NET
Number of Devices: 1005
Number of Events: 293
I would like to hear your thinking on support for ZWave-Long Range. Clearly, there are few LR devices available now but that will change going forward. What is HS's thinking for support for LR? Will the present 700 series based controllers be updateable or will that require a new controller? When might HS support of LR be available?
Originally posted by ahuefner View PostI would like to hear your thinking on support for ZWave-Long Range. Clearly, there are few LR devices available now but that will change going forward. What is HS's thinking for support for LR? Will the present 700 series based controllers be updateable or will that require a new controller? When might HS support of LR be available?
https://z-wavealliance.org/what-is-z...r-from-z-wave/
- Likes 1
Originally posted by rjh View PostIf you enter a device name in the search box (or partial device name) (from the top bar) it will display the device and all events that use that device. I think that does what this issue is addressing. It even tells you if the device is used as a trigger or an action and clicking the link brings up the event in edit mode.
And yup, I'm still running 1.7 in parallel with HS 3 because of some older plugin support issues and hardware devices.
1.7 was the cleanest, meanest of the bunch. I just checked and I haven't rebooted or even restarted HS 1.7 in over 3 months! Now that's stable!
- Likes 1
Our current 700 series boards should work with it, and I don't believe the firmware needs to be updated, but if so, it can be updated.
We are looking into it. It is doable with our existing code base, but the node ID is now 16 bits vs 8 bits. This is a big code change so it will take some time. I cannot give a timeframe right now but will post something after we scope it out.
- Likes 1
Originally posted by rjh View PostThe V4 plugin has the node info page, what is missing from it? It should have all the same information.
I haven't needed to deal with routing issues in a while. I guess I will start using the V4 plug-in and see how it goes. I already see I will miss the functions "Test Connectivity", "Remove Bad Node" and "Optimize" on the Z-Wave tab. It is available from The Z-Wave Device Diagnostics page, but the list is unsorted, making it difficult to find a device (I currently have about 175 Z-Wave Devices).HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
A V4 plugin update is being worked on and it will have the ability to adjust polling and the Z-Wave tab will have a direct link to one of the operations you mentioned so you can get their quickly.
We decided to leave the routing settings out for a number of reasons. With the latest Z-Wave technology routes are discovered automatically using an explorer frame. Also, there are cases where routing can change even after you set a route. Since there is no way to lock a route, we felt it best to remove this. (You can lock the routes for the entire interface but that is a bad idea)
Originally posted by randy View PostSorry, I hadn't loaded the latest V4. I was still running V3. That said, the page is improved. It is still missing the ability to clear or set routing info and the Z-Wave tab on the devices still doesn't allow for adjusting polling. I know that is supposed to come back. I would like to be able to clear the routing info.
