any idea how to edit the device to get rid of the missing child device?
device not exist in log
There are 4 parent devices with reference to features that no longer exist. You might need to use Jon00’s grouping plugin to fix the references. It appears that there are features assigned to the parent that are no longer there. That usually means the features were manually deleted. How did you create these devices?HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
The relationships are stored in the devices. Jon’s plug-in edits those relationships. Just pull up the parent device and clear it using Delete Device Relationship Status on those devices, which should show as ROOT. Within the root device it references all the Features assigned to it.
