Go Control Thermostat Voice Control
    Hi all,
    How or what would be the command to control my thermostat through the echo? I have two devices, heat and air conditioner which show up separately in the echo devices. I need to be able to set the heat and ac points seperately so i can leave the thermostat in auto mode. Thoughts?
    For a thermostat to be controlled via Alexa, set the voice command on the root device, not on the features.
    Once that is set to something like "My Thermostat" you can:
    Alexa, set My Thermostat to Cool
    Alexa, set My Thermostat to 72 degrees
    Alexa, make My Thermostat cooler
    Alexa, make My Thermostat warmer
    etc.
    67 Z-Wave Nodes, 111 Events, 422 Devices
    Z-Wave, UPB, WiFi
    Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
      How would I change the heat and cool set points individually then?
        Its actually fine this way just leave it on auto and ask for two degrees higher or lower depending on what season it is. Thank you!
