Hello!
I've started having issues with HomeSeer seemingly orphaning plugin processes on my Ubuntu 22.04 box. This seems to be mostly related to the ZWave 4.0.3 Plugin (I haven't tested for others, but this process seems to be regularly stuck). I'll show what I mean with some screenshots:
This is where the process is at start. The PID is 169108 for the plugin process. If I stop the plugin from the web console (turn it off), this is what I see on the console:
You can see it complains about an issue with an Int16 then can't find a process with ID 0. Looking back at the process, I see the process is still running:
If I start a new ZWave plugin, I'm then left with TWO running ZWave processes:
Two (or more) running plugin processes for the same plugin is probably not how this was designed. More frustrating for me is HomeSeer loosing the plugin process creates issues when I go to reboot (among other possible things). If the virtual host needs to reboot, it is hung until it either kills the VM or HomeSeer shutdown timesout (15 minutes). What can I do to fix this "lost plugin" issue?
