Originally posted by shill
View Post
Alexa Does Not Discover Events
Originally posted by shill View PostUpdate: I removed the "bad" devices and included them again and the new versions of those devices were found successfully by Alexa. I took a backup of the system before I did that in case HST needs examples of this annoying problem.
So Sgt. Shultz did take a look at my system. I wanted to provide some feedback to others that might run into the same problem- Make sure the devices for which Alexa Discovery has been enabled have the "Control Use" set for that device. You find the "Control Use" when you click on the device and switch to the "Status/Graphics" tab.
- Make sure the device are on/off devices, dimmable devices or thermostats (I think Alexa also support locks). I think/assume this is all determined by what "Control Use" have been set but I am not sure.
- Some devices (like in my case) have a switch feature AND a light feature. Both of those have on/off states. This can confuse the discovery process when the voice control has been enabled for the parent device. If you have such devices disable the voice control on the parent and enable it on the features. At least that is my understanding.
- Likes 1
