Controller Issue
    Controller Issue
    I noticed none of my automations were working on my main floor this morning (I have 2 controllers).
    I saw the main controller was disabled so I thought it may be network issue.
    I'm able to ping the controller and bring up its web page so I'm certain the ip is correct.
    However I can't get Homeseer to talk to it.
    A couple of things you can try:
    1) Disable plug in and then enable it; or
    2) Shut down HomeSeer and restart.
      Thanks for the reply.
      I have disabled the z-wave plug in and re-enabled it.
      I have rebooted the controller and the homeseer computer.
      They just don't seem to be able to communicate.
      The log says
      12/10/2022 10:41:29 AM
      Legacy-Plugin
      Z-Wave Warning
      Trying to re-connect to Ethernet interface at IP 192.168.1.141...
      Legacy-Plugin
      Z-Wave
      Note: Only one system may connect to an Ethernet interface at one time. If 2 systems are connecting to your Z-Wave interface, HomeSeer will not connect.
      12/10/2022 10:41:17 AM
      Legacy-Plugin
      Z-Wave
      Main Floor: Getting node information from controller...
      Legacy-Plugin
      Z-Wave
      Main Floor: Processing data buffered by the interface while it was disconnected.
      12/10/2022 10:41:16 AM
      Legacy-Plugin
      Z-Wave
      Main Floor: Z-Wave Ethernet at IP 192.168.1.141, connected to interface ok.​
        Oh, okay, the old "Only one system may connect..." problem. That has been discussed somewhere else on this board (not sure where, at the moment). However, take a look in the "Config" folder for Z-Wave.ini, which you can open with note pad, and see if there is anything funky there regarding devices (e.g., duplicates or incorrect IP addresses for interfaces).
          Thanks for the help, but it appears OK. I don't see a duplicate or IP error.
          Would removing the Backup_interfaces section help?
          Here is what I have
          [Z-Wave]
          Key=C8-97-A5-F6-A9-70-DF-85-5-1F-73-3E-D6-E5-13-A6
          [Net_F2E99631]
          gZwavePollFailures=2
          NoHSZWave=False
          AlwaysAllowNonSceneDevices=False
          LogZWPollErrors=False
          [Settings]
          Networks=F2E99631,D7FD474B
          gConfigFilename2=C:\Program Files (x86)\HomeSeer HS4\Data\Z-Wave\Z-Wave2.db
          [Net_D7FD474B]
          NoHSZWave=False
          [BACKUP_Interfaces]
          IFace_0_Name=Basement
          IFace_0_Unique=2CBC4C5BE22A
          IFace_0_IsMain=True
          IFace_0_HomeID=D7-FD-47-4B
          IFace_0_Node=1
          IFace_0_Model=1
          IFace_0_EthernetIP=192.168.1.130
          IFace_0_EthernetPort=2001
          IFace_0_Disabled=False
          IFace_0_ZNETName=Z-NETv4Basement
          IFace_1_Name=Main Floor
          IFace_1_Unique=F1B6412FE149
          IFace_1_IsMain=True
          IFace_1_HomeID=F2-E9-96-31
          IFace_1_Node=0
          IFace_1_Model=1
          IFace_1_EthernetIP=192.168.1.141
          IFace_1_EthernetPort=2001
          IFace_1_Disabled=False
          IFace_1_ZNETName=Z-NETv4MainFloor
          [Interfaces]
          IFace_0_IsMain=False
          IFace_0_Node=1
          IFace_0_Model=1
          IFace_1_IsMain=True
          IFace_1_Node=0
          IFace_1_Model=1
          IFace_1_Disabled=True
          [Net_Friendly]
          HomeID_0=F2E99631
          Name_0=Main Floor Network
          HomeID_1=D7FD474B
          Name_1=Basement Network
            Sorry, I can't see any issues with your Z-Wave.ini file. Do you have a backup to compare with? Also, take a look here for suggestions: https://forums.homeseer.com/forum/ho...wave-interface
              Thank you again.
              There is a file Z-wave.ini.bak in the same folder but it is identical and has the same timestamp.
              I reviewed the thread and tried disabled the controller, rebooting the controller, and re-enabling it and it did not help.
              I also rebooted the server again just for good measure but no luck.
              I have created a support ticket as well
                Can you ping 192.168.1.141 from your HS computer? That "generic" log message is usually an indication that HS didn't get a response from the interface. The last time I had this happen, I put a monitor/keyboard on the Z-Net and found that it was not booting. Re-flashed a new SD card and all worked again.
                Hope this helps.
                  Hope this helps.
                  Yes, I am able to ping the controller from the HS computer. I can also access the web page for the controller from the HS computer.
                  Also, I have temporarily disabled the firewall on the HS computer.
                    I have seen problems with Z-Nets not properly populating the ARP tables for hostname. Try configuring it as an Ethernet Interface at 192.168.1.141 and port 2001. See if it will connect by IP.
                    HS4 Pro, Windows 10 pro
                      I was able to add it as an Ethernet Interface. However nothing is working at the moment.
                      Attempting to connect to the controller gets:
                      ControllerFunction/Start cannot be called with the main interface of the target API=Nothing​
                      Click image for larger version  Name:	image.png Views:	0 Size:	106.2 KB ID:	1580208
                        That is odd to have 2 connected interfaces yet only one showing. Just confirming that Basement is at a different IP. If you have two controllers at different IP addresses, yet only 1 HomeID showing, it would seem that the controller at 141 has been erased or has a bad daughtercard. I sent you a PM.
                          Huge thanks to Randy! He walked me through restoring a backup and everything is working again!!
                          Thank you!!!
