I try to run HS4 on a RPi with 64 bits PiOS. I installed mono without problems but if I run ./go from the HS4 directory I get an error message:
Unhandled Exception:
System.TypeLoadException: Could not load type of field 'HSConsole.My.MyProject:m_ComputerObjectProvider' (0) due to: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies.
[ERROR] FATAL UNHANDLED EXCEPTION: System.TypeLoadException: Could not load type of field 'HSConsole.My.MyProject:m_ComputerObjectProvider' (0) due to: Could not load file or assembly 'Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies.
Searching on the internet I found the suggestion that ASP.NET is missing.
So I installed this as described in https://learn.microsoft.com/en-us/dotnet/iot/deployment
Without succes.
I think this is not a HomeSeer problem but something with RaspberryPi, but perhaps someone ran into the same problem here.
Anyone?
Without succes.
Anyone?
