I have a Fibaro "button" that is working fine. When I click on the "Manage" button on the "Z-Wave" tab for this device, it shows it as node 49. I can wake it up and verify connectivity to it (see screen snip Home below). When it is pressed, the associated events are triggered, etc. However, this device does NOT appear in the node information report (see screen snip Forum below). I tried doing a "rescan", but that didn't help. I tried going into the Z-Wave config and clicked "Reset Z-Wave Data" to rebuild the database. While that appeared to run successfully, this node does not appear. How does this happen and what should I do?
Thanks for your help.
FYI: I only happen to run across this issue because I was trying to get a count of the number of Z-Wave devices I have. I noticed that this one was missing. I'm not going to look through the list in greater detail to see if there are other anomolies.
Screen Snip #1
Screen Snip #2
Screen Snip #1
Screen Snip #2
