HS4 Log Error
    HS4 Log Error
    Hello,
    I'm getting a log error with HS4 every 5 minutes. It looks like the error i get when running one of my faulty scripts. But does not say "error running script".
    I have disabled my events one group at a time and the error still comes up every 5 minutes.
    This instance shows the error on the 0 and 5 minute mark, that is purely coincidental, other times it is at the 2 and 7 or 3 and 8 minute mark.
    I don't get this error with HS3 running the same events and scripts.
    This does not impact functionality, it's just annoying.
    Where to start to troubleshoot?
    Paul
Name:	HS4 Log 12-31-22.jpg
    I assume you have disabled all events to confirm it is a script causing the error?
    Unfortunately, the errors give no clue as to what is causing the message. All I can suggest is you try the 'fix device/feature relationships' option under Setup > Labs. I don't think that will help as something is trying to update a feature device with an invalid reference.
    Jon
      It may be the case that one of your device has an issue. Have you installed any new devices recently? I had that error once when a motion sensor I tried to install had issues during the install process. I had to uninstall and reinstall the device twice to get it cleaned up. Try checking your logs to see what z-wave devices were being accessed within a few seconds to see if there is one in common.
        Thanks for your responses.
        I've had a couple busy weeks, as I'm sure you all have, and am now getting back to this.
        Yes, all my events have been disabled. Didn't help.
        I then tried disabling my plug-ins one by one.
        When I disable the JowiHue plug-in, the error log entries go away. It must have a 5 minute update feature or something.
        I am using the HS4 JowiHue version.
        I'll now try and verify the lamp id's etc. I've got 36 bulbs so it may take a bit.
        If I have no luck there, I'll toss the question over to the Jowihue plug-in page.
        Thanks again for your help,
        Paul
