I am getting the following error messages when I start up HS4 Pro:
Starting up....
1/11/2023 9:00:06 PM HomeSeer~!~Error~!~Could not add Z-Wave to the plug-in list. Is this a duplicate? Check for two plug-ins with the same plug-in name.
1/11/2023 9:00:06 PM HomeSeer~!~Error~!~Initializing plug-in(1): Z-Wave Instance::General error setting up environment in InitIO: Could not load file or assembly 'System.Data.SQLite, Version=1.0.87.0, Culture=neutral, PublicKeyToken=db937bc2d44ff139' or one of its dependencies. The system cannot find the file specified. at HSPI_ZWave.ZWDatabase.GetDBVersion(Boolean& InvalidDatabase) at HSPI_ZWave.Database_Utils.LoadConfig(String filename) at HSPI_ZWave.HSPI.InitIO(String port) Time to load: 205 milliseconds
1/11/2023 9:00:06 PM HomeSeer~!~Error~!~SQL Exception adding record(s) to the LOG database(0): database disk image is malformeddatabase disk image is malformed, Code=11 SQL=
1/11/2023 9:00:09 PM HomeSeer~!~Error~!~SQL Exception adding record(s) to the LOG database(0): database disk image is malformeddatabase disk image is malformed, Code=11 SQL=
1/11/2023 9:00:11 PM HomeSeer~!~Error~!~SQL Exception adding record(s) to the LOG database(0): database disk image is malformeddatabase disk image is malformed, Code=11 SQL=
1/11/2023 9:00:14 PM HomeSeer~!~Error~!~SQL Exception adding record(s) to the LOG database(0): database disk image is malformeddatabase disk image is malformed, Code=11 SQL=
1/11/2023 9:00:17 PM HomeSeer~!~Error~!~SQL Exception adding record(s) to the LOG database(0): database disk image is malformeddatabase disk image is malformed, Code=11 SQL=
1/11/2023 9:00:19 PM HomeSeer~!~Error~!~SQL Exception adding record(s) to the LOG database(0): database disk image is malformeddatabase disk image is malformed, Code=11 SQL=
1/11/2023 9:00:22 PM HomeSeer~!~Error~!~SQL Exception adding record(s) to the LOG database(0): database disk image is malformeddatabase disk image is malformed, Code=11 SQL=
1/11/2023 9:00:24 PM HomeSeer~!~Error~!~SQL Exception adding record(s) to the LOG database(0): database disk image is malformeddatabase disk image is malformed, Code=11 SQL=
1/11/2023 9:00:27 PM HomeSeer~!~Error~!~SQL Exception adding record(s) to the LOG database(0): database disk image is malformeddatabase disk image is malformed, Code=11 SQL=
1/11/2023 9:00:29 PM HomeSeer~!~Error~!~SQL Exception adding record(s) to the LOG database(0): database disk image is malformeddatabase disk image is malformed, Code=11 SQL=
1/11/2023 9:00:32 PM HomeSeer~!~Error~!~SQL Exception adding record(s) to the LOG database(0): database disk image is malformeddatabase disk image is malformed, Code=11 SQL=
1/11/2023 9:00:34 PM HomeSeer~!~Error~!~SQL Exception adding record(s) to the LOG database(0): database disk image is malformeddatabase disk image is malformed, Code=11 SQL=
1/11/2023 9:00:37 PM HomeSeer~!~Error~!~SQL Exception adding record(s) to the LOG database(0): database disk image is malformeddatabase disk image is malformed, Code=11 SQL=Startup Complete, 15 errors detected, check the log for more information.
Can anyone tell me how to get rid of these errors? I have attached the start up log too.
Thank You,
John Turi
Starting up....
Thank You,
John Turi
