I was hoping to get other peoples experiences using HS4Pro. After moving I've recently begun setting things up again at the new house. I installed HS4Pro on a micro form factor computer. When HS4Pro starts it utilizes almost nothing resource wise. The computer is using 6-9 watts so thermals are all fine. After awhile I'm finding that the ZWave plugin suddenly starts to use significant processor resources. Energy consumption goes up to like 25-30 watts and the thing starts to cook. Has anyone run into this and know why or how to stop it? The issue seems to be with the zwave plugin. If I restart the program everything goes back to normal. I've considered moving to something like a raspberry pi, but I'm not sure how that would work as I don't think it could provide the kind of processing power it is requesting. Thanks for any help.
HS4Pro CPU utilization
It's a known issue with the plugin and usually manifests after adding a device. What version of the plugin are you running?HS4Pro on a Raspberry Pi4
HSTouch Clients: 1 Android
If you have a problem like this, you probably need to "open a ticket." As far as I know, HST is still using the sheer volume of tickets regarding a specific issue to assess the importance of a bug. I don't know how important they feel this bug is, but IMHO this is severe enough that I personally wouldn't even try a 4.x Z-Wave PI (especially without the ability to revert) as long as the complaints in this forum are running long, deep, and continuous. YMMV.
HomeSeer Version: HS4 Pro Edition 4.2.19.0 (Windows - Running as a Service)
Home Assistant 2024.3
Operating System: Microsoft Windows 11 Pro - Desktop
Z-Wave Devices via two Z-Net G3s
Zigbee Devices via RaspBee on RPi 3b+
WiFi Devices via Internal Router.
Enabled Plug-Ins
AK GoogleCalendar 4.0.4.16,AK HomeAssistant 4.0.1.23,AK SmartDevice 4.0.5.1,AK Weather 4.0.5.181,AmbientWeather 3.0.1.9,Big6 3.44.0.0,BLBackup 2.0.64.0,BLGData 3.0.55.0,BLLock 3.0.39.0,BLUPS 2.0.26.0,Device History 4.5.1.1,EasyTrigger 3.0.0.76,Harmony Hub 4.0.14.0,HSBuddy 4.51.303.0,JowiHue 4.1.4.0,LG ThinQ 4.0.26.0,ONVIF Events 1.0.0.5,SDJ-Health 3.1.1.9,TPLinkSmartHome4 2022.12.30.0,UltraCID3 3.0.6681.34300,Z-Wave 4.1.3.0
As a workaround (i.e. bandage fix) you could plug it into a smart plug with power monitoring capability and when a high power draw is detected, restart the Z-Wave plugin. There's several threads on doing this for other devices and plugins."if I have seen further [than others], it is by standing on the shoulders of giants." --Sir Isaac Newton (1675)
Originally posted by kenm View PostAs a workaround (i.e. bandage fix) you could plug it into a smart plug with power monitoring capability and when a high power draw is detected, restart the Z-Wave plugin. There's several threads on doing this for other devices and plugins.
Originally posted by randy View PostI use Jon00’s performance monitor plugin and trigger on high CPU usage.
"There's more than one way to skin a cat.""if I have seen further [than others], it is by standing on the shoulders of giants." --Sir Isaac Newton (1675)
