Suffix and decimals for status devices
    On HS3 I could define a devices as status only and specify the number of decimal places and prefix/suffix for the device value when it was displayed. For HS4 I don't seem to be able to do define a feature without having a control appear on the display. Is this still possible? The device/feature is controlled by mcsMQTT and is defined there as a status only device. It is not changed by HS4 - it is set by a remote system.
    HS4 doesn’t allow for the editing of status/value pairs on a root device. You can use the legacy page by <HomeSeer IP>/deviceutility where you can still edit a root device. With Jon00’s Links plugin it is available through the Legacy menu where he has wrapped an HS4 header around it. You can set it as Status Only and remove any controls.
    HS4 Pro, 4.2.18.3 Windows 10 pro, Supermicro LP Xeon
      Got it - thanks. Still finding some things that aren't as easy as I would hope.
