I could really use some help fulling figuring out what is causing this. Event & Log screenshots attached
Issue:
Delays of 4 to 10 seconds completing an event when triggered physically using a Zooz ZEN30 dimmer. The same event completes instantly when using HS4 Web UI to control the same dimmer (which triggers the same event).
Event:
EasyTrigger Groups are used. 'Any' device change detected in Group triggers a sync of 'all' dimmers in this group (4 dimmers).
In the log, I see HS4 event running all commands within 1 second. I'm assuming when HS knows about the change of a given dimmer in the event triggers instantly, no delay... which is why using the Web UI made all the dimmers update withn 1 second.
this makes me conclude that either....
(A) delay is caused by a lag with HS Zwave Plugin processing the Zwave status from the dimmer when its sent from the dimmer, not the UI
or
(B) Zooz ZEN30 dimmer has delays sending status to HS
I'm not sure if I can use HS4 debug to actually when the Zwave PI receives a status update from a device? Have not had time to work that yet.
If you have seen this issue, or have any troubleshooting advice... much appreciated!
Issue:
Event:
or
