Can't backup on Debian 11
    Just installed Debian 11 on a pc, then installed HS4.
    If I try to do a backup, it just sits with the "Backup Progress" window open and never advances at all.
    If I click the "Edit" button to change backup options, literally nothing happens.
    Not sure what is different about Debian but I did the same process I do for Ubuntu, only difference is this pc is 32 bit only.
    Tried to reinstall, tried to copy the html folder from a working linux install. No change.
    Running the latest beta but also tried with 4.2.16 with no difference.
    Mono version = Mono JIT compiler version 6.12.0.182
    Here's my install process.
    apt-get install mono-devel
    apt-get install mono-roslyn
    apt-get install flite
    apt-get install chromium
    apt-get install aha
    apt-get install ffmpeg
    apt-get install alsa-utils
    apt-get install curl
    install HomeSeer​
    Any ideas?
    Is there anything in the logs?
    What are the permissions of your directories?
      Are you doing this as user "homeseer" ? If so, you might need to add homeseer to the sudoers file and use sudo in front of each apt-get
      67 Z-Wave Nodes, 111 Events, 422 Devices
      Z-Wave, UPB, WiFi
      Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
        No, the OS install has nothing to do with Homeseer, just plain Debian so I added my own users.
          When you installed homeseer what exactly did you do? What user was used to install?
