Hey All,
Managed to get a basic setup of this working in HS4 as I consider migrating away from Z wave.
The Deconz app seems to have lots of information I assume I shouldn't play with!. One thing that would be useful ( but I can't see ) is there anyway to see the wireless strength between nodes? i.e. so I can spot a weak spot and perhaps add another device to act as a repeater?
I'm using the JowiHue plugin as recommended. I currently have some simple zigbee plugs that as far as I can tell just support ON/OFF. The JowiHue app though shows dimming options if I set an event for them ( not just on/off ). In the HS4 devices view there is no information on the switch apart from on/off.
Finally. With Z wave the devices are stored on the z wave stick yes? ( in essence if that dies I need to re add everything ). How does this work with the zigbee combee 2 stick? ( assume worst case scenario and it dies! )
Any advice/help welcome.
