Backup involving multiple Z-Nets
    This topic has been asked and answered, but the clarity of the answers was occluded in a morass of dead links concerning "Homeseer Help." What is the best practice in using Homeseer to back up multiple z-nets?
    HomeSeer Version: HS4 Pro Edition 4.2.18.1
    Operating System: Microsoft Windows 10 Pro - Desktop
    Z-Wave Devices via two Z-Net G3s
    Zigbee Devices via RaspBee on RPi 3b+
    WiFi Devices via Internal Router.
    Enabled Plug-Ins
    AK Weather 4.0.5.37,AmbientWeather 3.0.1.9,Big6 3.34.0.0,BLBackup 2.0.63.0,BLGData 3.0.55.0,BLLock 3.0.39.0,BLUPS 2.0.26.0,Device History 3.3.1.0,EasyTrigger 3.0.0.76,Harmony Hub 4.0.14.0,HSBuddy 3.30.1003.1,JowiHue 4.0.8.7,LG ThinQ 4.0.24.0,rnbWeather 4.4.0.0,SDJ-Health 3.1.1.4,TPLinkSmartHome4 2022.12.30.0,UltraCID3 3.0.6681.34300,Z-Wave 3.0.11.0 2
    You shouldn’t need to bother, since a backup is created with each inclusion or exclusion. If you want a manual backup, you need to do one for each controller. David zwolfpack helped me put together an automatic backup script. I’m not using it any longer. I could probably dig it up again.
    HS4 Pro, 4.2.18.3 Windows 10 pro, Supermicro LP Xeon
      Let me be more specific. I'm running Version 4.16.2.0 and thinking of upgrading to the latest beta. I obviously want to cover my backside as I have been epically burned by HST betas before. I am currently using BLBackUp and capturing the entire HS4 directory structure. I'm beginning to wonder if that is enough, since running multiple hubs is new to me. So, I'm thinking a manual backup might be a bit excessive, but very cheap insurance.
      1) So, that said, I think you are saying that for a manual backup, I need to back up all (both, in my case) Z-Nets via [Plugins>Z-Wave>{controller_Name}>Actions>Backup This Interface] for each hub and then do a manual backup of HS4 via [Tools>Backup/Restore>Backup Now]. Do I have that right?
      2) Does capturing the HS4 directory structure cover me entirely, if I lose a hub or hard drive? What do I not get in this step that I would have in step (1)? Anything?
      PS
      If step 1 is chosen, does one run restore just once?
      Enabled Plug-Ins
        Randy if you can dig up that script that would be most helpful.
          PS
          Your Z-Nets automatically create a backup in the /data/Z-Wave folder each time an inclusion or exclusion is performed. A backup of the entire \HomeSeer HS4 directory will also backup the backups. Z-Wave node data is stored in flash memory on the Z-Nets. While backups are important, unless the daughter card in the Z-Net fails, that data is stable.
            It might be tomorrow, but I’m sure I have it in backups.
              Your Z-Nets automatically create a backup in the /data/Z-Wave folder each time an inclusion or exclusion is performed. A backup of the entire \HomeSeer HS4 directory will also backup the backups. Z-Wave node data is stored in &las memory on the Z-Nets. While backups are important, unless the daughter card in the Z-Net fails, that data is stable.
              Thanks, that makes me feel better. I really wish we had documentation on this stuff...
              Enabled Plug-Ins
                Then I wouldn't have the post count that I do
                  https://forums.homeseer.com/forum/li...-backup-script
                  Not compatible with Z-Wave plugin v4 ...
                    Thank you.
                      Thanks. How about the G3 Znet with the banana PI or unknown and I'll have to test it?
                        ROFL.... Yep!
                        Enabled Plug-Ins
