HS4 Release Announcements 4.2.18.0 is available!
This topic is closed.
    Update through setup or see the release notes for download links.
    Release notes and download links:
    HS4 4.2.18.0 Release Notes​​
    4.2.18.0 installed and running without issue.
    Just a reminder that if you are upgrading from 4.2.17.0 or earlier, there is a change to Events that will not allow you to roll back to a prior version. A backup of your configuration is taken before the upgrade. As always, I recommend taking a full HS4 directory structure copy before any major update like this. The good news is that it is very unlikely you will have to roll back. Many of us have been testing the betas for weeks without issue. The other good news is that you will get Conditional Actions, a very useful new addition.
    You can look here for instructions for rolling back to your prior version.
    HS4 Pro, 4.2.18.3 Windows 10 pro, Supermicro LP Xeon
      I've added the warning and the reversion instructions to the .18 release notes. So, everything should be included now.
        Upgrade went well and I did not lose my Event Actions this time - thanks HST!
        67 Z-Wave Nodes, 111 Events, 422 Devices
        Z-Wave, UPB, WiFi
        Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
          Is .18.0 the same as .17.4 ? Or should I upgrade again?
            4.2.18.0 per rjh is the same as 4.2.17.5. .5 had a couple of changes from .4
              So, upgrading from Setup always reboots the (Windows) system now? No way to reliably upgrade without rebooting?
              HS4 newbee
              Gary
                EDITED! SEE BOTTOM FOR EXTRA INFORMATION
                After upgrading from 4.2.17.0 I am not seeing many of my devices on the Devices screen. I do not think they are missing because I can get information about at least one of them which was created a couple days ago via Michael McSharry's mcsMQTT Associations tab as well as in the popup when I select the Device ID. Also, when I select a device to edit from the HomeSeer Devices page and then change the url to use this device ID instead, I see information on the device. Below are image of the Device Editing page and the Devices where I am filtering on the appropriate Floor. I did see this specific device prior to the update.
                Click image for larger version  Name:	image.png Views:	0 Size:	97.6 KB ID:	1596050
                Click image for larger version  Name:	image.png Views:	0 Size:	36.9 KB ID:	1596051​​EDIT
                If I use the Search and search for pillar then the device is listed, but clicking on it gives me the information shown below:
                Last edited by ksum; March 2, 2023, 03:32 PM. Reason: Added information about using the Device page's Search for the device
                Karl S
                HS4Pro on Windows 10
                1070 Devices
                56 Z-Wave Nodes
                104 Events
                  Click image for larger version  Name:	image.png Views:	0 Size:	200.8 KB ID:	1596052
                  What happens when you toggle hidden from view off?
                    Toggling this On/Off makes no difference.
                    I DO see the device in the Control Device list when editing an Event and can also control the device via an event.
                    Karl S
                    1070 Devices
                    56 Z-Wave Nodes
                    104 Events
                      Have you tried a different browser?
                      Z-Wave, UPB, WiFi
                        Phone and PC. I also used the Chrome DevTools and there are no html divs for the missing devices. So I'm doubtful it is browser based.
                        I also have this in the phone app:
                        Should show all devices:
                        Many of these dashboard items do not show in the browser Devices page.
                        Karl S
                        1070 Devices
                        56 Z-Wave Nodes
                        104 Events
                          That is very strange.
                          Have you tried a reboot?
                          Z-Wave, UPB, WiFi
                            No problems upgrading from 4.2.17.5 to 4.2.18.0 on my HomeTroller Pi. Continuing to combine and replace my "parity" events. 😁
                              I read this notice.
                              Click image for larger version  Name:	image.png Views:	0 Size:	39.9 KB ID:	1596101
                              Will my events and actions configured in v4.2.17.0 work in v4.2.18.0?
                              Last edited by hembhagat; March 3, 2023, 04:14 AM. Reason: Corrected the version numbers
