backup/Restore all greyed out
    Hi.
    Why is everything in Tools/Backup/restore greyed out. Edit button does nothing. I am the admin user. Same with Chrome and Firefox.
    Thank you
    Br,
    Dali​​
    Pressing the 'Edit' button simply unlocks the fields you see initially so you're able to change them. The page display itself doesn't change.
      No, that's the thing. Edit button does absolutely nothing.
      Can not change anything. Can not click on anything else but Click here for more info
      Br,
      Dali
        Can you click backup now? That way you might get asked where to backup to. Right now it says default.
        On mine, when I click edit, I can make changes the edit button changes to a green "save" button.
          Hi.
          It will pop up the Backup Process window, but will not start. It just sits there.
          c:\Program Files (x86)\HomeSeer HS4\html\backups\ is empty
          Click image for larger version  Name:	image.png Views:	0 Size:	80.8 KB ID:	1596327
          Same for versions 4.2.17.0 and 4.2.18.0. Restarting HS4 or the computer does not help.
          Also tried to run HS using Run as Administrator (right click menu).
          Br,
          Dali
            For a test, I installed a clean install on another PC. Here it does work
            Back on the server...
            I could force the edit mode using a direct URL.
            http://localhost:8085/backup.html?edit=true
            But the Save button will do nothing (Just like Edit Button, prior to this)
            Click image for larger version  Name:	image.png Views:	0 Size:	81.0 KB ID:	1596329
            Something strange is going on here.
            Br,
            Dali​
              Permissions on the directory?
                Well, it's Windows. Never had to set it.
                  Ha, found it by luck.
                  Setup/Network
                  I had this disabled and it seems there is a bug.
                  After I enabled it, it started to work.
                  Thank you all for your help!
                  Br,
                  Dali
                    Setup/Network
                    Br,
                    Dali
                    I don't see the relationship between MyHS and local backups. I tend to agree with you that "... it seems there is a bug...".
                      Cloud backup (on same page) is the relation that is breaking I guess.
                      Br,
                      Dali
                        is there any way to report the bugs somewhere?
                        Br,
                        Dali
                          https://dev.homeseer.com/servicedesk...ion=portal%2F2
                          HomeSeer Version: HS4 Pro Edition 4.2.19.0 (Windows - Running as a Service)
                          Home Assistant 2024.3
                          Operating System: Microsoft Windows 11 Pro - Desktop
                          Z-Wave Devices via two Z-Net G3s
                          Zigbee Devices via RaspBee on RPi 3b+
                          WiFi Devices via Internal Router.
                          Enabled Plug-Ins
                          AK GoogleCalendar 4.0.4.16,AK HomeAssistant 4.0.1.23,AK SmartDevice 4.0.5.1,AK Weather 4.0.5.181,AmbientWeather 3.0.1.9,Big6 3.44.0.0,BLBackup 2.0.64.0,BLGData 3.0.55.0,BLLock 3.0.39.0,BLUPS 2.0.26.0,Device History 4.5.1.1,EasyTrigger 3.0.0.76,Harmony Hub 4.0.14.0,HSBuddy 4.51.303.0,JowiHue 4.1.4.0,LG ThinQ 4.0.26.0,ONVIF Events 1.0.0.5,SDJ-Health 3.1.1.9,TPLinkSmartHome4 2022.12.30.0,UltraCID3 3.0.6681.34300,Z-Wave 4.1.3.0
                            Setup/Network
                            Br,
                            Dali
                            Just tried the same, doesn't fix it for me.
                              Did you saved the settings?
                              it takes a while before Edit button turns to Save and you can make changes on the Backup/Restore page.
                              Br,
                              Dali
