Scripting Help
    Scripting Help
    Hi,
    I'm trying to log the value of some Zigbee temperature and humidiy sensors in the HS4 log via the &nhs.writelog command. I've got it working fine referencing the values with hs.devicevalue:
Name:	Screenshot 2023-03-07 235218.jpg
Name:	Screenshot 2023-03-08 001358.jpg
    But if I use hs.devicevaluebyname (which would be my preference), then I always get a value of -1:
Name:	Screenshot 2023-03-08 000312.jpg
Name:	Screenshot 2023-03-07 235504.jpg
    I've tried multiple iterations of the device name, but always get the same results. I believe this is a problem with the device name I'm using since I get the same -1 result even if I use garbage for the device name. Hoping someone can point out what I'm doing wrong.
    I tried it and could not get it to work with any HS4 created devices. Most probably linked to the parent/feature relationship changes in HS4.
    It does still work fine with HS3 created devices (in HS4) but not surprising as it is a HS3 scripting function.
    There is not an equivalent HS4 function I can see either...
    Jon
      tenholde, don't you use "name" a lot? Have you noticed this?
      HomeSeer Version: HS4 Pro Edition 4.2.18.1
      Operating System: Microsoft Windows 10 Pro - Desktop
      Z-Wave Devices via two Z-Net G3s
      Zigbee Devices via RaspBee on RPi 3b+
      WiFi Devices via Internal Router.
      Enabled Plug-Ins
      AK Weather 4.0.5.37,AmbientWeather 3.0.1.9,Big6 3.34.0.0,BLBackup 2.0.63.0,BLGData 3.0.55.0,BLLock 3.0.39.0,BLUPS 2.0.26.0,Device History 3.3.1.0,EasyTrigger 3.0.0.76,Harmony Hub 4.0.14.0,HSBuddy 3.30.1003.1,JowiHue 4.0.8.7,LG ThinQ 4.0.24.0,rnbWeather 4.4.0.0,SDJ-Health 3.1.1.4,TPLinkSmartHome4 2022.12.30.0,UltraCID3 3.0.6681.34300,Z-Wave 3.0.11.0 2
        I prefer to use a device/feature name as that is less likely to change than the device ref (which screws up existing events). You can use GetFeatureRefByFullname to get the devref and then use hs.DeviceValue. See the link below for more information:
        https://tenholder.net/tenWare2/Scrip...eRefByFullname
        tenholde
          My thoughts exactly.
          I understand what you're suggesting as a solution, but I was hoping to accomplish this as a one line immediate script command in order to keep it simple.
          Is there some place that lists all the Homeseer script commands and functions? I've searched through the documentation and cant seem to find this.
            Well, there is this: http://help.homeseer.com/help/HS3/static/
            However, it is for HS3 scripting, is incomplete, has errors, and is sorely lacking in examples, but it is all HST has given us to work with. Probably the best approach is to engage in self-help as far as possible, using the documents available, then get the brain trust available, here, to help sort your attempt out.
            Enabled Plug-Ins
              To find the device by name it uses the following case-insensitive checks, iterating over all devices and stopping on the first match - and treating devices and features the same:
              Entered string =
              Location + " " + Name AND Location <> ""
              OR Location2 + " " + Name AND Location2 <> ""
              OR Location + " " + Location2 + " " + Name
              OR Location2 + " " + Location + " " + Name
              OR Name
              So in your case you'd want to look for "Zigbee Dining Room Humidity" for maximum accuracy.
                For the actual scripting, attached is a dump of all the public members of hsapplication - some of the new ones may be obvious, but without proper documentation it would be trial-and-error.
                HS4 scripting.txt
                The plugin documentation https://homeseer.github.io/Plugin-SD...tml?vb#methods has a lot of overlap, so some of that helps.
                For example, a nice new method which simplifies CAPI control is SendControlForFeatureByValue
                  tenGlobalMethods.GetFeatureRefByFullname has been updated to include an optional parameter FeatureNameOnly. If set to True, then the Featurename parameter should only be the Name without Location and Location2.
                  https://tenholder.net/tenWare2/Scrip...tallation.aspx
                  See documentation at: https://tenholder.net/tenWare2/Scrip...eRefByFullname
                  Or if you use tenScripting: https://tenholder.net/tenWare2/tenSc...tallation.aspx
                  tenholde
