Most devices missing after upgrade
    Hello,
    I am running version 4.2.12.0 and have been for some time. I decided to update today and when HS was re-run it offered the update which I accepted. Everything seemed to go ok. However when it finished I clicked devices and there were only 7 listed I had 310 devices before.
    I tried re-installing and still the same, I restored the backup and still the same. Luckily I had a copy of the install directory which I changed the name back to the install directory. I was now back to the older version and as soon as I ran all my devices were back.
    Has anyone had anything similar or know why this is happening.
    Thank you
    Ian
    Your database probably got corrupted and so all you see is virtual devices. I bet all your events are gone, too. Did you enable backups in HS4? If so, restore that backup. The backup is under the tools menu on the HS4 portal. If you didn't enable backups through HS4 then do you have any other backups through a 3rd party backup program? If so, make a copy of your C:\Program Files (x86)\HomeSeer HS4 (the one that is broken now, just in case) and do a restore of that folder from your 3rd party backup program.
      4.2.18.0 has a documented device corruption problem. It is fixed in beta 4.2.18.1 but I see the latest is 4.2.18.3.
      Now that your system is healthy again, I'd shutdown, take a full backup, and use the offline update method to get to 4.2.18.3.
        Hello
        Thank you for the replies.
        The 7 devices were actual not virtual devices and the events were still there. As mentioned even doing a backup restore did not fix the issue!
        I was not aware of the 4.2.18.0 bug. I will back up again and then download 18.3, by offline do I understand this as making sure HS is shutdown and then running the install?
        Thank you
        Kind regards
        Ian
          Correct. Shutdown HS and make a full directory backup. This will ensure that no files are "in use" by another process. Then run the offline installer while HS is still shutdown. Finally, restart HS.
          Download the offline installer from one of the links below.
          Windows or Linux (not sure about Raspberry Pi).
            Hello,
            Many thanks for your help.
            I'm pleased to say 18.3 installed correctly and all the devices are present.
            Kind regards
            Ian
              Great to hear. IMHO, 4.2.18.0 should be pulled until 4.2.19.0 released.
