HS has always been case agnostic on Event names. I wouldn’t ever want two identically named Events (with different case usage) either. Perhaps HS could handle the renaming of an Event better, but case sensitivity would present some problems.
HS4 Release Announcements 4.2.18.3 is available!
This is a sticky topic.
Originally posted by randy View PostHS has always been case agnostic on Event names. I wouldn’t ever want two identically named Events (except case usage) either. Perhaps HS could handle the renaming of an Event better, but case sensitivity would present some problems.
Originally posted by John245 View Post
It is not that I want two event with identical names. I did want to correct the name. By this behavior additional steps are needed.
Put an extra character at end of name and save. <---- extra step.
Edit name again removing character and making case change, save. Done.
HS4 Pro, 4.2.18.3 Windows 10 pro, Supermicro LP Xeon
I have also done it.but expected a more user friendly experience.
John
Originally posted by TC1 View Post
I don't disagree, but your original statement said "By this behavior additional steps are needed...." implying something more tedious than one step. Ideally it should work better, but one step every now and then (unless you're constantly changing the case on your words) is not going to make-or-break the current product, IMO.
nothing more… nothing less..
Originally posted by John245 View Postrjh
I created the event. At time of event creation the control status were respectively On and Off
Then I updated the control status to respectively Open and Closed.
I noticed that the event did not longer work and when checking the event the control actions were empty.
The issue is that control actions of an event will not be updated in case the control status of a device is updated.
Hope this explains the issue.
John
regards Paul
Originally posted by Paul32 View PostHi John, I noticed this also inversion HS 4.2.16.0. So this not new to version 4.2.18.3
regards Paul
Despite the fact that it is maybe not new. It would be good to resolve this.
And I think this is the moment as HS is working on the event engine.
John
- Likes 1
Hi Paul,
John
Work around for event name changes and CAPS -- just add a character to the name, save it, then re-edit with the desired name. This caps issue has been out there a while.
As far as 18.3 -- been in production for 3 days. All is well. Upgrade from 17.0 was very smooth - no issues in the upgrade process. Events are working fine. All devices are appearing and working well. Backups are working fine. I've yet to find a use for the conditional processing enhancements, but still "noodling" the feature for future use. Am pleased with this upgrade so far.
- Likes 1
