Any news on HS4?
  • Any news on HS4?
    I know HS3 is reliable and it works fine for most people, but at this point, it is just super duper dated. It's been like 4 or 5 years since last major upgrade. In the software world, that's a lifetime!! Anyone know when HS4 is being released? Is it even being developed?
    I doubt it is even been considered for development at the minute - I'd be shocked if it was.
    I think the fundamental architecture is relatively solid, the interface and event engine is pretty stable. The UI is what people see and judge the product on and what is lacking, that is a complaint that is echoed quite often but no news on what may be in store in terms of UI improvements. There was mention of a HSTouch replacement but no news on that in a while and no ideas what that will bring.
    My Plugins:
    Yeelight 3P | Nanoleaf 3P
      Plenty of things in HS3 need fixing!
        I agree, plenty needs to be fixed and plenty needs to be added. The Event engine works fine, but it can DEFINITELY be improved. Currently, for many simple tasks u need to create multiple events. A more advanced engine should be able to handle all that in a single event... The interface is whole story by itself. It looks like it was made in the 90's... Again, it works and it's stable, but it is definitely time for a major refresh and upgrade.
          My God.
          What's the problem?
          The event engine doesn't "look" modern but it works? Should they put more icons or emojis in there or something? I'm confused. Maybe paint it purple? Or go with the current trend and make everything white and flat?
          These kind of comments spring up every now and again and I think that ultimately what folks are looking for is a nice remote control UI. But I may be mistaken. HSTouch will usually answer those questions if one is willing to take a few days to work it, though it does have its own quirks. Otherwise there is Imperihome and the Spud plugin. I have no idea why it took that long for someone to make an Imperihome plugin but Kudos to Spud.
          Originally posted by rprade
            Perfect Setup
            Let the complaints begin!
              HS8?
              HS3 quietly has undergone several major revisions that I think some companies would bill as new versions. Those big revisions all involved new features that were not on the list of features when I purchased my HS3 Pro upgrade. Look at the recent betas of 332-340 that are introducing large changes in how HSTouch works for example. If you factor in large revisions like the time multithreaded event handling was added, JSON support, IFTTT\Echo\MyHS...I count 4-5 major revisions since it was released.
              HS8 FTW!
              _______________________________________________
              HS3 : HSpro (3.0.0.460) on Win2012 (vm on ESXi)
              Plugins: HSTouch, UPBSpud, Kinect, Nest, IFTTT, DirecTV, EasyTrigger, Imperihome, Zwave, RFXcom, UltraMon3, UltraWeatherBug3, UltraGCIR3, UltraLog3, UltraPioneer, PHLocation, Pushover, Pushalot, MCSSPrinklers S, JowiHue
              Jon00 Plugins: Bluetooth Proximity, Performance Monitor, DB Chart, Links
                All companies should have a 3-5 yr plan. You can bet they have a general roadmap if they want to be competitive.
                Sent from my Galaxy S7 Edge using Tapatalk
                  I never realize that HS3 is dated because as far as I know there aren't many new ways to turn on a light, open a garage door, arm and alarm system. HomeSeer 3 is an automation engine that simply works for most. The new front ends are now the new VR engines like the Echos, Dots, Google Homes, etc. True automation shouldn't require much of a front end as the point is to automate.
                  -Rupp
                    Do you have examples as I'm sure Mark and crew would like to know this.
                    -Rupp
                      I think we should limit this to actual problems, not improvement or enhancement requests.
                      I'll start with 2
                      1. Group conditions are broken
                      2. When editing an event a trigger should not be allowed to be deleted - deleting the primary trigger breaks the event. Deleting a secondary trigger (OR IF) should be allowed, but all associated conditions must be removed as well or the event is usually broken.
                      There are others and I'm certain someone else can point out more.
                      Not directly HomeSeer, but the HSTouch designer is so buggy as to have an almost impossible learning curve.
                      Contemporaneous change logs on the core program and plug-ins would be very nice.
                      I have no problem with the look and feel of the current interface, when HomeSeer is working correctly, I don't even look at it. I have no problem with the design of the event engine. It will do most anything that needs to be done. There are a few missing event functions that fortunately have been added by Spud. I don't care that it takes several events to accomplish things, it wouldn't be any improvement to be able to try to do too many things within a single event.
                      Randy Prade
                      Aurora, CO
                      Prades.net
                        It would probably be easier to check the black hole of bugzilla....
                          I'll start with 2
                          +1 Agree
                          HS3 3.0.0.548 &HSTouch Designer 3.0.71 with 887 Devices, 515 Events
                          Plugin's:
                          BLBackup, BLOccupied, BLShutdown, EasyTrigger, Ecobee,
                            After the considerable effort involved in moving from HS2 to HS3 there's no way that I'd consider HS4.
                              Yeah, you should really check Bugzilla for things that are broken and enhancement requests.
