I just ordered a restore flash for my SE. Does anyone know if i can replace "Sample.mb" on the flash drive so that when i restore i will get my origional devices with the restore?
Hometroller se restore flash
You need to copy your HomeSeer folder to a backup drive, then use the restore drive to put the image on the Home Troller and then bring your saved folder back over. If you have a HomeTroller SE Pro you will need to run the HSPro updater from homeseer.com/downloads as well, ignoring the message about it being the incorrect updater. Your HS license is on a sticker on the bottom of the HomeTroller.-Rupp
Ok, Great. Thanks for the quick reply.
Originally posted by Rupp View PostYou need to copy your HomeSeer folder to a backup drive, then use the restore drive to put the image on the Home Troller and then bring your saved folder back over. If you have a HomeTroller SE Pro you will need to run the HSPro updater from homeseer.com/downloads as well, ignoring the message about it being the incorrect updater. Your HS license is on a sticker on the bottom of the HomeTroller.
