HomeTroller-SE PRO Updater only shows release 2.5.0.52
    Hi,
    I have a HomeTroller-SE PRO
    HomeSeer Version: Professional Edition 2.5.0.52
    When running the updater, it only shows version 2.5.0.52 as the latest version available to update to, however it looks to me like version 2.5.0.80 is available. Is it possible to update to the latest version?
    I had a notice on the updater to run the HSPRO Updater, however when I run it it says:
    Installed version: PRO100, Installing PRO. This is not the correct updater for your homeseer product.
    I aborted the installation as I did not want to cause problems.
    The latest update and all HomeSeer executables updates are all ways available here:
    http://www.homeseer.com/downloads
    The HS updates are slow to get loaded into the updater.
    -Rupp
        Have you rebuilt your hardware and loaded the Pro-100 version of HS on your HomeTroller?
        -Rupp
          No, at least not knowingly. At one time I tried to upgrade to a new version from the download page, a long time ago, then it said my license was no longer valid, so then I restored it back to what I thought was original version again.
            Did you ever get an answer to your question?
            I am trying to update my hometroller that is running hspro in the c:\program files \homeseer pro directory.
            Seeing the same error you see.
            If I try to upgrade it then it seems to put it in the program files Homeseer HS2 directory.
            Any ideas will be appreciated.
              Did this hardware once have HS2 prior to Pro? If so there's most likely a left over registry setting pointing to the wrong location if HS2 wasn't removed prior to loading HSPro.
              -Rupp
                That is a possibility.
                Don't remember if I upgraded to the Pro before I bought the Hometroller or after.
                All I know is it has been running in the Homeseer Pro directory for a good while.
                It would be nice to be able to upgrade to a later version. Think I am on 2.5.0.21 and would like to get to the latest version.
                Thanks...Sonny
                  Thanks...Sonny
                  You can upgrade by changing the installer to install in your current HSPro directory.
                  -Rupp
                    That sounds great.
                    were do I change it?
                    Is that an option when I go to the download page?
                    If it is, I must have missed it.
                    Thanks Rupp.
                      That sounds great. were do I change it?
                      It's an option on the installer.
                      -Rupp
                        The full installer has an option to change the install location. The update installers do not.
                        -Rupp
                          Check the registry path for HS and make sure it's correct.
                          HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\HomeSeer Technologies\HomeSeer 2
                          Check Installdir
                          -Rupp
