how do you back up .mdb files and /or the entire Homeseer folder to a USB drive on HometrollerSE ?
back up .mdb ???
Just copy the directory over to the USB stick.
Make sure that HS is not running when you do this.
Part of the backup stuff for Homeseer 2 today relates to a copy and compress to zip of the Homeseer directory. I have used it if really needed for DR. For DR just rename the Homeseer directory to Homeseer-old and copy over the Zipped file, expand it to Homeseer and you are good to go.
Copying the whole directory insures you that you got everything.- Pete
Auto matorHomeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU 16Gb
HS4 Lite - Ubuntu 20.04 / VB W7e Jetway JBC420U591 Fanless IntelĀ® Celeron N3160 SoC 8Gb
HSTouch on Intel tabletop tabletsX10, UPB, Zigbee, ZWave and Wifi MQTT automation-Tasmota-Espurna. OmniPro 2, Russound zoned audio, Smartthings hub, Hubitat Hub, and Home Assistant
Yup; curious why you cannot log into the XPE box remotely or directly?
You cannot do anything else really until you figure this out.
The following is related to XP and should also work fine with your XPE setup.
If you have forgotten your password, if you have another user account with administrative privileges you can log into that account and change your original user account's password from the User Accounts applet in Control Panel. If you don't have another account like this set up or don't have the password to it, you'll need to log into the built-in Administrator account. In XP Home, boot the computer into Safe Mode. Do this by repeatedly tapping the F8 key as the computer is starting up. This will get you to the right menu. Navigate using your Up arrow key; the mouse will not work here. Once in Safe Mode, you will see the normally hidden Administrator account. The default password is a blank.
In XP Pro, you do not need to go into Safe Mode. At the Welcome Screen, do Ctrl-Alt-Del twice to get the classic Windows logon box. Type in "Administrator" and whatever password you assigned when you set up Windows.- Pete
