Pro-100 Compatability Support
    The AC RF processor is an desired product for my Pro-100 package sales strategy.
    After reading the thread below, you will discover that updater package file size is restricting installation in the limited space currently available to the Pro-100 D: drive. (10mb in my current config)
    I ask that you provide assistance in addressing this issue for the pro-100 dealer market and perhaps build a special updater for the pro-100 product line that includes all NECESSARY files and a seperate updater package or download file for the docs etc...
    HS HELPDESK INFORMATION---------------------
    I installed the AC RF Processor
    I purchased the AC RF processor
    I was given
    Product: AC RF Processor
    License ID: xxxx
    Password: xxxx
    I enter the information for on-line registration
    Pro-100 displays-------
    Registration error!
    Bad license file
    Neal Nilsen
    11-Mar-2006-5:45 PM
    EDIT I performed the un-protect feature before running updater.
    Please use the HomeSeer updater functionality if at all possible. The updater has the ability to install or update system components that may be required by the plug-in. If for some reason you need to manually install the plug-in you must make sure the latest versions of msstdfmt.dll and tabctl32.ocx are installed and registered on your system. These two files are generally located in your windows system(32) directory. The ACRFComm.dll file must be present and the hspi_ACRF.ocx file must be present and registered in your HomeSeer directory for the plug-in to work properly.
    msstdfmt.dll is NOT in windows/system32
    tabctl32.ocx is in windows/system32
    Geoff Epstein
    12-Mar-2006-11:53 AM
    Neal,
    Please shutdown HomeSeer, then delete the file "AC RF Processor.lf" from the "HomeSeer 2\config" folder. Finally try to install update from the Updater again.
    Geoff Epstein
    HomeSeer Technologies, LLC
    nnilsen
    12-Mar-2006-1:44 PM
    EDIT The file is not found at that location
    I cleaned the disk to allow 316mb on C: 13.6 on D:
    Install fails and reduces the available space on D: to 0mb
    3/12/2006 1:29:39 PM - Start -
    3/12/2006 1:29:39 PM - Start - HomeSeer version 2.0.2041.0
    Starting Now
    3/12/2006 1:29:39 PM - Shutdown - Ending plug-in process hs_compatibility
    3/12/2006 1:29:39 PM - Startup - Loading Settings
    3/12/2006 1:29:39 PM - Startup - Settings Loaded.
    3/12/2006 1:29:40 PM - Startup - Loading configuration file ...
    3/12/2006 1:29:40 PM - Info - Loading device types file...
    3/12/2006 1:29:40 PM - Database - Opening up HomeSeer database D:\Program
    Files\HomeSeer 2\Config\nacnet_2.mdb
    3/12/2006 1:29:41 PM - Info - Loading Devices...
    3/12/2006 1:29:41 PM - Load Config - 53 total devices loaded.
    3/12/2006 1:29:41 PM - Load Config - Checking device type settings for all
    devices...
    3/12/2006 1:29:42 PM - Load Config - Finished checking device type
    settings.
    3/12/2006 1:29:42 PM - Load Config - Loading Events...
    3/12/2006 1:29:42 PM - Load Config - 36 total events loaded.
    3/12/2006 1:29:42 PM - Info - Loading TV Timers...
    3/12/2006 1:29:42 PM - Database - HomeSeer configuration database
    D:\Program Files\HomeSeer 2\Config\nacnet_2.mdb has been closed.
    3/12/2006 1:29:42 PM - Info - HomeSeer version is: 2.0.2041.0
    3/12/2006 1:29:42 PM - Info - Initializing phone interface...
    3/12/2006 1:29:43 PM - Info - Adding phone line 1 Name: 304-724-1056 Modem:
    Way2Call Hi-Phone Desktop
    3/12/2006 1:29:43 PM - Info - Initializing Hi-Phone device...
    3/12/2006 1:29:48 PM - Updater - Starting installation of updates
    3/12/2006 1:29:48 PM - Updater - Applying update: ACRF Plug-In
    3/12/2006 1:29:56 PM - Error - Error processing file AutomationCraft RF
    Processor Documentation.rtf, size is 2049, and error is There is not enough
    space on the disk.
    3/12/2006 1:29:56 PM - Error - Error setting creation date for file
    'AutomationCraft RF Processor Documentation.rtf', error is The process
    cannot access the file "d:\program files\homeseer 2\updates2\ACRF
    Plug-In1.1.0.11\AutomationCraft RF Processor Documentation.rtf" because it
    is being used by another process.
    3/12/2006 1:29:56 PM - Updater - Copying file: d:\program files\homeseer
    2\hspi_ACRF.ocx
    3/12/2006 1:29:56 PM - Updater Error - Unable to install files, is HomeSeer
    running? Please exit it now if so. (Retry in 5 sec.)
    3/12/2006 1:30:01 PM - Updater - Copying file: d:\program files\homeseer
    2\hspi_ACRF.ocx
    3/12/2006 1:30:01 PM - Updater Error - Unable to install files, is HomeSeer
    3/12/2006 1:30:01 PM - Updater Error - Error installing file: hspi_ACRF.ocx
    , is file open?
    3/12/2006 1:30:01 PM - Updater Error - Detailed error: 0
    3/12/2006 1:30:01 PM - Updater Error - Installation aborted.
    3/12/2006 1:30:01 PM - Updater Error - Installation of package ACRF Plug-In
    failed. Installation will be attempted the next time the application is
    started.
    3/12/2006 1:30:01 PM - Updater - Installation of updates completed, but one
    or more were unsuccessful and will be attemped again at the next restart.
    3/12/2006 1:30:02 PM - Startup - Checking for available plug-ins
    3/12/2006 1:30:02 PM - Info - Found plug-in: X10 CM11A/CM12U, version:
    1.0.1.0
    3/12/2006 1:30:03 PM - Info - Found plug-in: Media Center, version: 2.0.0.2
    3/12/2006 1:30:03 PM - Info - Found plug-in: SmartHome PowerLinc USB,
    version: 1.0.0.7
    3/12/2006 1:30:03 PM - Info - Found plug-in: Power Monitor, version:
    1.0.0.1
    3/12/2006 1:30:03 PM - Info - Found plug-in: Touchpad, version: 2.0.0.21
    3/12/2006 1:30:04 PM - Info - Found plug-in: Media Player, version: 2.0.0.7
    3/12/2006 1:30:05 PM - Startup - Restoring device status
    3/12/2006 1:30:05 PM - Startup - Initializing Plug-Ins
    3/12/2006 1:30:05 PM - Info - Initializing X10 Plug-in: SmartHome PowerLinc
    USB On USB
    3/12/2006 1:30:05 PM - Info - Initializing Plug-in: SmartHome PowerLinc USB
    3/12/2006 1:30:06 PM - Info - PowerLinc USB Plug-in, Version 1.0.7
    3/12/2006 1:30:07 PM - Startup - PowerLinc USB initialized successfully
    3/12/2006 1:30:07 PM - Info - Done initializing X10 interface SmartHome
    PowerLinc USB
    3/12/2006 1:30:07 PM - Startup - IR Label file (config\irlbl.cfg) missing
    or corrupt, creating new file
    3/12/2006 1:30:07 PM - Info - Done initializing infrared interface
    3/12/2006 1:30:07 PM - Info - Initializing Plug-in: Power Monitor
    3/12/2006 1:30:07 PM - Power Monitor I - Power Monitor Plug-in Register
    callback complete
    3/12/2006 1:30:07 PM - COM Plugin - Calling InitIO
    3/12/2006 1:30:07 PM - COM Plugin Info - Power Monitor Initializing...
    3/12/2006 1:30:09 PM - Info - Done initializing plug-in Power Monitor
    3/12/2006 1:30:09 PM - Info - Initializing Plug-in: Media Player
    3/12/2006 1:30:10 PM - Info - Media Player plug-in version: 2.0.7
    3/12/2006 1:30:10 PM - COM Plugin - Calling InitIO
    3/12/2006 1:30:10 PM - COM Plugin Info - Media Player version: 2.0.7(c)
    2002-2005 HomeSeer Technologies, LLC
    3/12/2006 1:30:10 PM - Info - Windows Media Player version: 9.0.0.3250
    3/12/2006 1:30:10 PM - Startup - Media Player foreground initialization
    completed
    3/12/2006 1:30:10 PM - Info - Done initializing plug-in Media Player
    3/12/2006 1:30:10 PM - Startup - Media Player background initialization
    started...
    3/12/2006 1:30:10 PM - Info - Initializing Plug-in: Media Center
    3/12/2006 1:30:10 PM - COM Plugin Info - Media Center Initializing...
    3/12/2006 1:30:10 PM - Media Center - Media Center 2.0.2 Configuration
    initializing.
    3/12/2006 1:30:10 PM - Media Center - Media Center Configuration completed.
    3/12/2006 1:30:10 PM - Error - Unable to write to log file HomeSeer.LOG,
    disabling file logging. There is not enough space on the disk.
    3/12/2006 1:30:10 PM - Error - Unable to close log file HomeSeer.LOG,
    3/12/2006 1:30:10 PM - Info - Done initializing plug-in Media Center
    3/12/2006 1:30:10 PM - Info - Initializing Plug-in: Touchpad
    3/12/2006 1:30:10 PM - COM Plugin Info - Touchpad Initializing...
    3/12/2006 1:30:10 PM - Touchpad - Touchpad 2.0.21 starting.
    3/12/2006 1:30:10 PM - Startup - Touchpad is configured for HomeSeer 2.0
    3/12/2006 1:30:10 PM - Touchpad - Touchpad Configuration completed.
    3/12/2006 1:30:10 PM - Info - Done initializing plug-in Touchpad
    3/12/2006 1:30:11 PM - HSPhone - HomeSeer Phone Web Interface initializing.
    3/12/2006 1:30:11 PM - Info - Local IP address is: 192.168.1.9
    (255.255.255.0)
    3/12/2006 1:30:11 PM - Info - Web Server thread started on port 80
    3/12/2006 1:30:11 PM - Startup - Initializing email 1 1
    3/12/2006 1:30:11 PM - Startup - Initializing text to speech
    3/12/2006 1:30:11 PM - Info - Email receive thread started
    3/12/2006 1:30:12 PM - Info - Listening for remote speaker connections on
    port 8742
    3/12/2006 1:30:12 PM - Startup - Start remoting
    3/12/2006 1:30:12 PM - Startup - Start event processing
    3/12/2006 1:30:12 PM - Info - This version of HomeSeer is registered.
    3/12/2006 1:30:12 PM - Startup - Running startup script
    3/12/2006 1:30:12 PM - Startup - Scripting is OK
    3/12/2006 1:30:12 PM - Info - Initializing email for MAPI
    3/12/2006 1:30:12 PM - Info - Done with scripting
    3/12/2006 1:30:12 PM - Startup - Starting scheduler
    3/12/2006 1:30:12 PM - Info - Starting the HS2 Sentry EXE
    3/12/2006 1:30:12 PM - Startup - Start up complete.
    3/12/2006 1:30:14 PM - Info - MAPI Init, found 0 messages
    3/12/2006 1:30:14 PM - Info - Mail login successful
    3/12/2006 1:30:15 PM - Database Item - Saving Event Controls VR
    3/12/2006 1:30:16 PM - Database Item - Saving Event Controls VR
    3/12/2006 1:30:16 PM - Database Item - Saving Event Genre VR
    3/12/2006 1:30:17 PM - Database Item - Saving Device Quick Genre
    3/12/2006 1:30:17 PM - Database Item - Saving Event Artist VR
    3/12/2006 1:30:18 PM - Database Item - Saving Device Quick Artist
    3/12/2006 1:30:18 PM - Database Item - Saving Event PlayList VR
    3/12/2006 1:30:19 PM - Database Item - Saving Event Album VR
    3/12/2006 1:30:19 PM - Startup - Media Player background initialization
    completed
    3/12/2006 1:30:20 PM - Database Item - Saving Device Quick Album
    3/12/2006 1:30:38 PM - Info - Speaker client connected from: 127.0.0.1
    Neal Nilsen
    12-Mar-2006-2:02 PM
    EDIT After further examination I note the following
    Updates2 = 33mb
    zips = 1.49
    ACRF Plugin1.1.0.11 = 11.6mb
    administrator local settings = 82mb
    HS2 directory = 35.6mb
    I have installed a USB drive as E: and have offloaded the files to it.
    Can I manually Install from a drive other than D:
    Geoff Epstein
    12-Mar-2006-8:00 PM
    Neal,
    There is currently no way to install an update from another drive.
    I'm going to turn this help ticket over to another staff member who might have more ideas about how to resolve.
    Geoff Epstein
    No File Attached
    Rate This Response
    Neal Nilsen
    13-Mar-2006-12:25 PM
    EDIT Can I manually install files to the their locations
    Can I edit the install.txt file
    Richard Helmke
    15-Mar-2006-12:52 PM
    Yes, you can edit the install.txt to remove the doc files.
    Richard Helmke
    HomeSeer Technologies LLC
    No File Attached
    Rate This Response
    nnilsen
    17-Mar-2006-06:08 AM
    EDIT Is there a portion of a developers kit or sdk that a semi technical person can read to gain the knowledge to better understand the updater theory of operation. Is it available to non developers.
    Is it ok to just delete files from a zip and let updater log errors.
    -----Original Message-----
    Subject: {100-7513} RE: Registration Error~~
    Richard Helmke
    17-Mar-2006-3:59 PM
    There is no other doc other than the SDK. If you delete a file from the zip, you should delete its line from the install.txt file otherwise the error may cause the update to fail.
    Richard Helmke
