Pro-100 Video Port Shuts down
    I am having a problem with a Pro-100. I have been running it for a while and setting it up. I have allways had a monitor hooked up while testing. I then put the unit in the enclosure I have built and tested it by logging in over my network. Everything worked fine. Then removed the unit and hooked up a monitor again. The display works good until the "Powered by Homeseer Pro-100" blue screen shows up, the display disappears then the monitor says "looking for video signal". I have tried 2 monitors and it does the same thing every time. It is like when I ran it without a monitor 1 time it thinks there is no monitor and turns off the video output. I can still access the setup screen over the network and everything works. Is there a way to re-enable the video output?
