Huge Problem with my Pro-100
    Do you have a System Restore Flash for PRO-100 Series 2 that would be the easiest way to straighten out your PRO-100.
    http://store.homeseer.com/store/SYSR...-P396C102.aspx
      Not only is it the easiest way it's the only way if the OS susbstained corruption. You can login to the dealer products page to order this restore drive.
      http://store.homeseer.com/store/Deal...ducts-C28.aspx
      -Rupp
        Thanks guys..
        I do not have the restore unit, but made an ordre.
        Hope this will solve my problem.
        Have good one..
        Stones
          It will - have used several times - restores OS and HS back to factory defaults
            Kaldoon..
            And is it the same situation with HS uninstalled from my controller ?
              Yes it will make the PRO-100 like it was when you got both the OS and HomeSeer.
                Course you will want to back anything up that you want to keep as the restore flash does wipe the entire Pro-100 and you'll start from scratch.
