How to roll back HSPRO on PRO-100
    After updating HSPRO to 2.5.0.51 on PRO-100, Ztroller stopped talking to all zwave devices...
    How do I roll HSPRO back to an earlier version?
    Did you make a copy of your homeseer folder before upgrading? If so just shutdown HS and copy the old one back on top of the new one.
    Running HS PRO V2.5.0.49 & HS Pro V2.5.0.51
      No I didn't. Just ran Updater from HS.
        Usually a little back up is made in your HS2 directory.
        Shut all the HS2 things down and copy back the files you want.
        ~Bill
          Thanks Bill. I found several older versions under path:
          D:\Program Files\HomeSeer HSPRO\Updates2\HomeSeer PRO-100 Update Installer2.4.0.11\HomeSeerUpdate.exe
          D:\Program Files\HomeSeer HSPRO\Updates2\HomeSeer PRO-100 Update Installer2.5.0.23\HomeSeerUpdate.exe
          D:\Program Files\HomeSeer HSPRO\Updates2\HomeSeer PRO-100 Update Installer2.5.0.51\HomeSeerUpdate.exe
          Are these the correct files? How should I use them?
            I think you are supposed to run the HSRESTORE.EXE in that directory, but I have never done it.
            ~Bill
              Typically I just back up the entire HS directory and use the update file to downgrade what ever that may be. I've also never used the restore file.
              - Pete
              Auto mator
              Fanless IntelĀ® Celeron N3160 SoC 8Gb
                If you are going back to 2.5.0.44 just install that version - went back and forth several times between 44 and 51 yesterday currently back on .44
                  I went back and forth several times yesterday using the hsrestore.exe command in the directory of the version that you want to go back to. Seems to work well for me.
                  Chris
                    Chris
                    on my Pro-100, the only .exe file in the backup directory for different version is HomeseerUpdate.exe
                    Is HSPro setup differently for Pro-100 and other pc?
