Converting large HS2 software installation to Pro-100
    Hello, I have bought a pro-100. I have a fully functional and complex (to me) HS2 software installation on a regular computer and want to convert it to the Pro-100. My questions are. 1) will all these interfaces and devices work with the Pro-100. 2) What is the simplest approach for converting my existing system to the hardware Pro-100.
    My interfaces are
    Z-troller with some 100 devices
    MCSsprinklers with Rain8Relay hardware
    MCStemperature
    BC4 and BC4 ir setup with TV system and other devices
    Proliphix thermostat
    RFXcom with receivers/transmitter and lots of Oregon Scientific devices
    RFX charts
    z-wave thermostat
    Vista alarm with ad2usb hardware and lots of devices
    ACT TI103
    BLocuppied
    HStouch
    Insteon with a few devices
    ipPower with a few devices
    UPB with a few devices
    X10 with a few devices
    weather
    I have 2 Quatech internet to RS232 com hardware boxes (QSE 100) installed on the existing computer to provide com ports around the house. I would like to move these the Pro-100.
    And then there is the issue of wanting to preserve all my events and devices...
    I think that is it!
    Thanks in advance...
    Sent from my iPad using Tapatalk HD
    What version of the Homeseer software are you running? Make sure both are at the same version number. Make a backup copy of the HomeSeer directory on the computer. Make sure you know what port numbers are on all your serial devices in your current system.
    Shut down current system - move serial devices to Pro-100 utilizing same serial ports numbers
    Start up Pro-100 to make sure all serial devices start-up properly.
    Shut down HomeSeer -copy the Homeseer directory that you backed up from the computer system and overlay the HomeSeer directory on the Pro-100 - restart the Pro-100 and you should be up and running
      Thanks, I am using the latest beta but the pro-100 hasn't arrived and so don't know what version it will have, but I will make sure they are the same exact version.
      I also found this thread "How To move a HomeSeer configuration to another system or HomeTroller": http://board.homeseer.com/showthread.php?t=120948
