audio set-up
    audio set-up
    having trouble with getting audio out of my pro 100. here are some pix of what i get from control panel. nots ure what i need to do to enable TTS sound through there. it works fine on my HST device. but cant get it out of the Pro 100. thanks
    HS3 , Zwave, HometrollerS6, ELK M1G Ultra; mcs sprinklers; WGL800; BLRF; BLNetCallerID; BLSpeech
    What does control panel / system properties / device manager show under sound, video adn game controllers?
    I do not see your hardware audio driver in your pictures. For HD audio there is also typically a Microsoft UAA Bus Driver for High Definition Audio under the system devices.
    You need both of these for HD audio.
    - Pete
    Auto mator
    Fanless Intel® Celeron N3160 SoC 8Gb
      here it is pete
        HD audio? plain old audio? cant get anything out of the pro 100.
          HD audio is typical today. I see an optical out port such that your box is using HD audio. Newer HD is just the 3 ports and one being optical or analog.
          I looked at the manual and didn't the hardware specs for the audio.
          There is typically the mention of the audio hardware on the hardware specs.
          The exclamation point on the driver means that its not loading. Can you just reinstall the audio driver from scratch? It will be much easier. Shut down Homeseer before you update the audio driver.
          When did the audio quit working? Did it work before?
          Try going to this page to download the hotfix for UAA (plus look to see if it is there).
          I have attached the audio patch from MS. Rename it to an EXE file and run it.
          http://support.microsoft.com/kb/888111
          Then do a refresh of your hardware devices and it should install automatically.
          - Pete
          Auto mator
            not sure never tried it.
            so exit HS.
            then load what driver on the pro 100 and from where (arent you glad you asked?) thanks pete
              Will be back in a little bit....WAF stuff...
              - Pete
              Auto mator
                WAF = LIFE!
                  Which model of the Pro-100 is it?
                  OK....next steps go back to control panel and look at the system properties and look for "Microsoft UAA Bus Driver for High Definition Audio" first....the audio driver above will not work unless the Microsoft UAA Bus Driver for High Definition Audio is enabled and working.
                  If you run the above MS patch it will fix the UAA driver if its messed up and should automatically enable the other driver with the exclaimation point. If there is no UAA driver then the Microsoft patch program will see this and not patch up your system.
                  BTW TTS will come back once you have your audio driver running again.
                  Found it here. Guessing
                  http://www.lex.com.tw/product/MV823A_b.htm
                  If its a VIA CPU then the drivers are here:
                  http://www.lex.com.tw/download/driver-MV823A.htm
                  - Pete
                  Auto mator
                    the UAA bus driver is not listed in the system sound devices.
                    i may not have run the patch correctly. stumped for now
                      What specific model of the Pro-100 do you have?
                      The drivers above are for the VIA CPU version of the Pro-100.
                      - Pete
                      Auto mator
                        series II about 3 years old
                          Its the Celeron model and here are the drivers for it.
                          http://www.lex.com.tw/download/drive...-Series_b.html
                          When you get to the page use the drop down for the MI853AW drivers.
                          There are two audio drivers listed. Try one or the other. If it doesn't see the audio hardware it will not install.
                          - Pete
                          Auto mator
                            Ok. So in pro 100 download the file and it will automatically install or do I download it someplace specific
                              Yup; download the file(s) to some place specific first.
                              You then have to unzip the file. Not sure if the zipped files contain an installer or just the drivers. Tell me what you see when you unzip them.
                              I looked at the two zipped audio files and its the VIA one I think that will work for you. (IE: VIA(VT1612.1616).zip)
                              Once you unzip it there is a setup exe file in the root directory of the audio driver files.
                              - Pete
                              Auto mator
