HomeSeer for Polling Omni Pro II
  • HomeSeer for Polling Omni Pro II
    I would like to know what HomeSeer hardware/software would be required to poll and store Thermocouple Temp/Humidity and Thermostat Temp from an Leviton/HAI Omni. I have never used HomeSeer but I was told I could do this several years ago when I inquired at Cocoontech.
    Additionally, if there are several options, which options would also work with Amazon Echo/Alexa?
    Welcome to the Homeseer forum JackN.
    Homeseer Zee, Homeseer Pro, Homeseer Standard, Hometrollers all support the Leviton Omni Homeseer 3 plugin and yes you can poll Temperature/Humidity, Temperature and Omnistat Temperatures from the Leviton Omni Pro panels.
    I did that with Homeseer 2 and doing it today with Homeseer 3 and the Omni Plugin.
    For more information relating to the plugin see over here:
    HAI Panel for HS3 Plug-in (rmasonjr)
    Homeseer includes the Amazon Alexa plugin and you can utilize both just fine.
    I am Pete_C on the Cocoontech forum.
    - Pete
    Auto mator
    HS4 Pro - V4.0.5.0 - Ubuntu 18.04/W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.8X
    HS4 Lite -
