Vera to HS3... version & plugins needed?
  • #16
    Fair enough, I ask because my equipment stops responding to pings when I set it to standby.
    Is there an API, or web interface on the Denon? Potentially, you could create a VB script to go to the network interface on the receiver and get on/standby.
    Alternatively, if the Denon receiver can be configured to send a JSON command to HS3 you could configure it turn a virtual device in HS3 on or standby.
    • #17
      If you're is not responding to Ping then you cant remotely take it our of standby using the network... only IR or front panel button, correct? Otherwise Ping must work unless they have a specific setting to disable response to Ping - which I've never seen anything that sophisticated in an AVR, but it is possible.
      Yeah, I'm thinking I'll create a plugin myself. I only need to know 1 things from it. Cant be difficult (famous last words) ;-)
      • #18
        If it helps, the Harmony plugin DOES report back activity status, although NOT device status.
        I actually use this for a motion controlled light in my theater room. I have an event that turns off lights if no motion after 15 minutes....of course, if we are watching a moving and not moving, it would go off... so I placed a condition in that said if the "Watch Movie" activity was on, then do not run event.
        Works great.
        • #19
          I get that HS is worried about piracy. I think a self esteem
          huh?
          • #20
            Crudd, that was for the licensing post, I opted not to post on it as it didn't pertain to my install. I have deleted it.
