Add power consumption manually
  • Add power consumption manually
    In Vera, if your device don't support consumption reporting you can easily manually add this per device (for a double relay device you could add this per "output"). Is there a way to do this in HS?
    I've not found a way either. Doesn't seem possible
      I asked for something similar over a year ago as a feature request and noted in a thread here:
      http://forums.homeseer.com/showpost....9&postcount=14
      No luck so far....made sense to me too....
      -Travis
        I put this together a while back. Not the cleanest, but is a start:
        http://board.homeseer.com/showthread.php?t=180675
