Devices will not show up in device list in Device Management
    Starting situation:
    Z-Flash is open and interface is enabled. No devices are connect and Interface is erased before.
    I set up an new folder with firmware files in "C:\Program Files (x86)\HomeSeer\HomeSeer Z-Flash\updates" named "96_1_4"
    It holds one file
    When I now add the device I get this in the log:
    Add Node started...
    Activate the 'Add to Network' function on the device...
    A new node is being added...
    Adding a new DEVICE NODE...
    DONE - Add Node Operation is Complete.
    Done. Node 2 Added.
    Manufacturer information for node 2, ID: 96=60H (Everspring), Type: 4=4H, ID: 1=1H
    Node 2 is Z-Wave version: Lib: 2,64 App: 1.2
    Device sync complete.
    The device list in Device Managements remain empty:
    Same happens when doing it as second controller via another gateway (homee). The nodes are identified during adding but none apears in the device list.
    What am I doing wrong?
    The UI is buggy from what I have seen. If the devices don't show up. Close the app (don't press anything just close it), re-open the app, hit the enable button and your devices should appear.
      Thanks for your hint. I did exactly what you wrote, but the device did not show up.
      Even tried to "Erase Interface" first, than included the plug -> not showing up
      Closed the App. Reopend the App. Hit "Enable". The log shows:
      Initialization Done.
      Getting manufacturer information for existing devices...
      Getting Z-Wave node list for network F96D47A5...
      Found 2 Z-Wave nodes
      Syncing Z-Wave nodes with device list...
      Device synchronization needs to get Z-Wave class information for one node.
      Getting class information for node 1...
      Getting class information for node 2...
      Init Done.
      But nothing in the "Devices" list.
