How do I get ZFlash to use the CORRECT interface?
    This system has multiple Z-Net devices. It worked correctly on the first one (10.10.10.32) but now will not switch over to the next Z-Net interface (10.10.10.33). I have tried closing the ZFlash app and restarting it, and even thought the "Z-Net IP Address" clearly shows 10.10.10.33 it is clearly still accessing the wrong interface at 10.10.10.21 (see double-ended red arrow.)
    How do I get ZFlash to quit fixating on the old interface and switch to the new interface.
    I suspect that it might have something to do with the buttons label "Erase Interface" or "Add To/Remove From Existing System" but both of these have names that are too scary and too non-descriptive to just try them.
    How do I move to the next Z-Net interface on the ext IP address?
Name:	Screen Shot 2021-05-30 at 17.16.21.png
    Same problem here. Anyone?
      Welcome to the club. Sorry, but it is not a very exclusive club.
      No known solution or workaround.
        Not a Z-Flash user - but have you tried disabling the unwanted interface in the Z-Wave plugin while running the Z-Flash procedure.
        (Whatever you do, don't "Erase this interface" !!)
          Yes. HS has admitted it is a bug. But it is not a high enough priority to fix.
