Basic inclusion exclusion issue
  • Basic inclusion exclusion issue
    I'm sure this is pretty basic, but here goes. I'm evaluating HS3 with a smartstick+ z wave controller. I have z-tool+ installed and discovering HS3.
    For about 4 years I've had a Vera Lite with about 5 GE zwave switches. 2 3way circuits and a regular.
    I assume from my research I need to remove the switches to reset them, then add to my HS controller.
    In z-tool+ I press remove, then press on, then off on the switch. Several seconds later it says activate the 'remove from device' function on the device. I do it again. Then it repeats the message.
    I assume this means it's not detecting the device. Once (after the fourth time in the cycle) it said "found a node to remove". Was right around the time I pressed abort though.
    For grins, I tried adding the devices instead - that seemed to work every time, but it said "adding SLAVE NODE". So I aborted because I assume that's not what I want.
    I would've thought maybe it was an NWI distance issue since these are older switches, but the add seemed to register. So I'm not sure what to think.
    Help & thoughts? Thanks.
