Contacting HomeSeer This Week
See more
See less
Z-tool won't connect
  • Tomgru
    I'm now getting the ""Error connecting to homeseer, version 3.0.0.194 or later is required, or JSON disabled:An error occurrred while sending the request". when I try this on my android phone.
    Support had me back off the zwave beta back the release... thought that might be it. Reinstalled beta - no go.
    Tried ecetron advice with the two ports... still doesn't work.
    Tried just turning the Firewall off... nope.
    I use this all the time,... any ideas what to try next?
  • ecetron
    Finally got the no connection (grayed out buttons; JSON error; GetInterfaces error)... need to open the firewall to allow both the JSON port (11000 is the default) AND, that was the big one, the main URL Port for HS3 -- in my case 85. That allows it to get to the interfaces and then the 11000 for all the rest... sigh
  • mulu
    I am having the same problem. I disabled the local firewall but that didn't help. Any input is appreciated...
  • jayph
    I'm having the same problem with z-tool+, but I never get any error messages. The buttons just stay grey. I disabled the firewall on the local network on my S6 Pro, and then it connected as normal. If I knew which port it needed I could unblock it.
  • ecetron
    Same as everyone else... I have a SmartStick+ and a Z-net. Both work just fine. Z-Seer seems to work (although it refuses to see the Z-net interface). But Z-tool+ refuses to connect. I have tried opening ports 10200, 10400, and 10401 which HS3 has listening... but no luck... Any suggestions are welcome. Thanks.
  • CharizardsFire
    Same issue as TexARC - get various errors form the z-tool+ app on my s8. Z-net adapter is green and connected to server... HS3 3.0.0.435 . Thinking it may be related to having the server running in a VM. Any thoughts?
  • TexARC
    Were you ever able to get past the JSON error message? I've been unable to get ZTool to work on my Pixel 2XL, with the Z-Net ethernet adapter on Hometroller 6 with HS3 3.0.0.435 .
    Of course, the list of things I can't get to work right with Homeseer far outstrips the things I can get to work right.
  • simplextech
    Originally posted by larrywal32 View Post
    Made progress - what @Rupp said helped. It looks like it's the Domain firewall on Windows Server that's blocking it. When I disable it, it works ok.
    Anyone know how to add a rule to explicitly allow z-tool+ through when in network?
    I have not messed with it enough to know it's port requirements other than port 80 to get to the HS Web interface. I don't use z-tool much as I just use the normal interface from a tablet when roaming around adding devices.
  • larrywal32
  • larrywal32
    Thanks! Did that reset, but z-tool+ is still failing . JSON disabled: an error occurred while sending the request.
  • simplextech
    Originally posted by chrisfraser05 View Post
    I'll be honest, I couldn't figure out how to factory reset the stick on homeseer.
    I installed Domoticz (free) on my PC and used the Zwave tools on it to do a factory reset of the stick.
    When I reconnected to Homeseer I saw the network ID was different to the last time and it worked with no issues.
  • larrywal32
    Yuck . Maybe I'll call HomeSeer tomorrow...
  • chrisfraser05
  • larrywal32
    I had already used it with a separate controller. Sounds maybe the same issue? How do you factory reset the stick?
  • chrisfraser05
    was the zstick brand new?
    I found the same issue as I'd originally used the stick as a secondary controller, I factory reset the stick and as primary controller Ztool was able to use it.
