Z-Tool causing high CPU issues
  • Z-Tool causing high CPU issues
    Rich / Mark, rjh Could one of you take a look into what is causing the CPU to jump to 50% usage or more when I use Z-Tool to add a device? I've gotten to the point where I don't even use it anymore because there is a 100% chance that it will cause my hometroller S6Pro to have this issue. The Z-Tool is such a great idea and I would hate to see it get forgotten.
    Thanks guys!
    Plugin's:
    Thanks guys!
    Not sure I understand the problem. if your CPU jumps to 50% while you're using Z-Tool+ and then it reverts back to normal usage when you disconnect Z-Tool, is that really a problem? Z-Tool+ is only designed to be used when adding devices to your network. That's not something that happens too frequently, right?
    Learn About HomeSeer
      Hey Mark,
      Sorry, I didn't explain the issue well. This issue has been around for quite a while and has been documented in a few places in the forum but hasn't been addressed yet. The issue is that when anyone uses Z-Tool to add a new device everything adds correctly but what you don't notice right away is that the CPU usage will jump to anywhere from 50% on up and stay pegged at that level until HS3 or the zwave plugin has been rebooted. It doesn't just stay at that level while using Z-Tool. Most don't notice right away until the high CPU usage causes other issues. Adding a device doesn't happen frequently, however, once Z-Tool is used to add a device, the affects last until reboot.
      I know that rprade has documented the issue in some of the HS3 beta threads as well.
      Plugin's:
        i just tried it on the test system in my office and couldn't replicate the problem. The test system is a HomeTroller S6 PRO running Windows 7e. I opened the task manager on the unit and then put Z-Tool into inclusion mode and added a plug-in switch to the system. CPU spiked momentarily at about 50% and then settled back to low usage. Here's the graph.
        So... guessing this must be system-specific. What are you using and how did you produce the problem?
          I’m using a Hometroller S6 Pro with the same OS. How many devices are on the system you added a device to? Try adding another device, it has happened on several systems so I’m surprised you aren’t seeing this issue....yet...
          Plugin's:
            Rich also tried it and couldn't replicate it on his development system. Does it only happen with Z-Tool or does it also happen with the standard web-based inclusion process?
              Yes, it can happen with the web based inclusion process as well but not as often as I’ve experienced with Z-Tool. I personally haven’t experienced it except for maybe once or twice with the web interface but I have seen others post that they have.
              In my experience, I would guess it’s shown up 85% using Z-Tool and maybe 10% using the web based process.
              All of my devices are z-wave+ devices, not sure if that matters or not but thought I would mention.
              Plugin's:
                It can happen with either method, so it is not a Z-Tool issue. I have not needed to include or exclude a Z-Wave device in many months, but the last time I did include a second device, the Z-Wave plug-in went to 40-60% CPU. It can also happen when doing a manual backup of a Z-Wave controller. Sometimes the CPU utilization will settle down on its own, other times the system or plug-in needs to be restarted.
                I will see if I can make it happen again this weekend. My system has consistently exhibited this behavior for at least a couple of years. Sometimes it has gone so wonky that I have to restart before I can work with a 3rd device.
                Randy Prade
                Aurora, CO
                Prades.net
                  Hey Randy, did you happen to have a chance to send Rich logs on this? I'm frustrated that it happened to me again last week while I was using the Web interface but didn't have a chance to get the logs. Our dog just had back surgery and my wife and I have been trying to keep up with everything we need to do for her. I may be buying a couple of dry contact switches soon so will try again when those arrive.
                  Just don't want to lose track of this, it has been something needing to be fixed for a while.
                  Plugin's:
                    I haven’t tried again since the above post. I’m waiting on 4 HS-WD200+ dimmers to swap out some HSWD100+. I’ll let Rich know if I can cause the issue again.
                    Randy Prade
                    Aurora, CO
                    Prades.net
                      I added three new sensors tonight and my z-wave plugin was using about 13% CPU on my system after doing so. I had to shut down and restart the plugin for it to drop back to the 0-1% it normally runs at. I run HS on an 8-core I7 system with 8 GB of RAM.
                        If you still have the logs to send Rich that would be great!rjh
                        Plugin's:
                          If you still have the logs to send Rich that would be great! @rjh
                          Do you know what logs he needs? I did not have any kind of debugging turned on, and there’s nothing unusual in the event log related to adding the three sensors.
                            I too have this behavior with Z-Tool+ to where I now only use the web interface. I have only used z-tool+ on my Android Phone. HS3 is running on Linux. I typically restart the Z-Wave plug-in to correct it. I tried it today to capture information if helpful. From the attached image, it's clearly only the z-wave mono process never returning to normal cpu.
                            Overall server cpu jumps and never returns to normal either.
                              rjh What information would best help you troubleshoot this issue? sparkman wasn’t able to see anything in his logs and the only place I can see it is in the task manager.
                              Thank you
                              Plugin's:
