Z-Tool causing high CPU issues
    #16
    Originally posted by The Profit View Post
    rjh What information would best help you troubleshoot this issue? sparkman wasn’t able to see anything in his logs and the only place I can see it is in the task manager.
    Thank you
    I repeated the same steps with the same results. I enabled zwave's Detailed Debug logging to .../Debug Logs which I am happy to provide.
    Len
    HomeSeer Version: HS3 Pro Edition 3.0.0.435
    Linux version: Linux homeseer Ubuntu 16.04 x86_64
    Number of Devices: 633
    Number of Events: 773
    Enabled Plug-Ins
    2.0.54.0: BLBackup
    2.0.40.0: BLLAN
    3.0.0.48: EasyTrigger
    30.0.0.36: RFXCOM
    3.0.6.2: SDJ-Health
    3.0.0.87: weatherXML
    3.0.1.190: Z-Wave
      #17
      That would be great! If possible, post them to this thread?
      Thank you
      HS4 4.2.6.0 &HSTouch Designer 3.0.80
      Plugin's:
      weatherXML, Jon00 Alexa Helper, Network Monitor, MyQ, Z-Wave
        #18
        Thank you
        I'll have to check the logs for any sensitive data before uploading, unless Rich wants me to PM them to him directly.
        Len
        Enabled Plug-Ins
        2.0.54.0: BLBackup
        2.0.40.0: BLLAN
        30.0.0.36: RFXCOM
        3.0.6.2: SDJ-Health
        3.0.1.190: Z-Wave
          #19
          I have seen this reported in the past, but so far we are not able to re-create it here on any system. Is this on Windows only? Are any web pages open on nay system when you use Z-Tool? Does it only happen when add device, remove a device, both? Or any other Z-Wave function? What type of device are you adding, and does that matter?
          πŸ’‍♂️ Support & Customer Service πŸ™‹‍♂️ Sales Questions πŸ›’ Shop HomeSeer Products
            #20
            I'm on Windows and added 3 EcoLink z-wave plus door/window sensors. I did not check CPU usage after the first and second one, only after the third and it was high and stayed high until I restarted the z-wave plugin. I have 3 more sensors on the way, so will do some additional troubleshooting when I get those. I've not seen it when removing devices, but typically only remove one device at a time. I may have HS web pages open when I do add them, but typically that would be a static page only and not any others. I never have the z-wave controller management page open on other systems when I use z-tool.
            HS 4.2.8.0: 2134 Devices 1252 Events
            Z-Wave 3.0.10.0: 133 Nodes on one Z-Net
              #21
              Rich, it looks like @Iveatch has logs that he can PM to you, would that help?
              I have a Hometroller Pro and do not have any windows open, just HS3 running and the Homeseer Speaker window open. I personally have just experienced it when adding a z-wave device and so far it hasn’t happened with any other function. It does happen with either with Z-Tool or the HS Web UI, not just Z-Tool. It doesn’t seem to matter what type of device that I am adding, it has happened with HS light switches, dimmers and also Qubino devices.
              Plugin's:
                #22
                I run HS on Linux (ubuntu server 16.04.5 LTS) on VMWare esxi 6.5. I do not have any HS web pages open, however, several HSTouch android tablets/phones. are connected 24x7.
                This happens for any z-wave device I add via z-tool+ via my android phone. I have attached screen captures of what occurs when removing a device. I ran two test. First test is where I clicked the remove device and aborted it after 10 prompts to start the exclusion process on the device. The second test is where I removed the device immediately. From the graph for test 2, you can see the z-wave mono cpu drop after the device was removed. However, there was a increase in z-wave cpu afterwards which persisted. During an add, I do not see this short drop in z-wave cpu as you can see from the graphs in my previous post.
                Click image for larger version  Name:	tempsnip.png Views:	1 Size:	87.6 KB ID:	1293662
                I do not have this issue when using HS web interface (chrome on windows). This is the same two tests performing an add of the same z-wave device.
                Len
                Enabled Plug-Ins
                2.0.54.0: BLBackup
                2.0.40.0: BLLAN
                30.0.0.36: RFXCOM
                3.0.6.2: SDJ-Health
                3.0.1.190: Z-Wave
                  #23
                  What version Z-Wave plugin is this? Also, what type of Z-Wave interface? SmartStick+ or Z-Net?
                    #24
                    Being in IT for 30 years, I tend to patch based on the patch notes and comments in this forum - so I patch a bit later than earlier. This issue, for me, pre-dates these patch levels.
                    I use a z-net connected via ethernet.
                    Z-NET V2 Configuration - Version 1.0.23
                    HS info:
                    Current Date/Time: 3/20/2019 12:19:40 PM
                    Linux version: Linux homeseer 4.4.0-141-generic #167-Ubuntu SMP Wed Dec 5 10:40:15 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux System Uptime: 24 Days 21 Hours 31 Minutes 36 Seconds
                    IP Address: 192.168.1.119
                    Number of Devices: 678
                    Number of Events: 798
                    Available Threads: 600
                    HSTouch Enabled: True
                    Event Threads: 99665
                    Event Trigger Eval Queue: 0
                    Device Exec Queue: 0
                    HSTouch Event Queue: 0
                    Email Send Queue: 0
                    Anti Virus Installed:
                    Enabled Plug-Ins
                    2.0.54.0: BLBackup
                    2.0.43.0: BLLAN
                    3.0.0.56: EasyTrigger
                    30.0.0.37: RFXCOM
                    3.0.6.7: SDJ-Health
                    3.0.0.91: weatherXML
                    3.0.1.249: Z-Wave
                    Len
                    Enabled Plug-Ins
                    2.0.54.0: BLBackup
                    2.0.40.0: BLLAN
                    30.0.0.36: RFXCOM
                    3.0.6.2: SDJ-Health
                    3.0.1.190: Z-Wave
                      #25
                      rjh Hi Rich, I've received the 3 devices that I need to add. What would you like me to capture to help troubleshoot this?
                        #26
                        Guys - Rich is working on a big project now and won't be able to put eyes on this for a few months. If restarting the plug-in alleviates the problem, then at least that's a work-around you can use in the meantime.
                        πŸ’β€β™‚οΈ Support & Customer Service πŸ™‹β€β™‚οΈ Sales Questions πŸ›’ Shop HomeSeer Products​
                          #27
                          Ok, on that note, I added the three devices using the web interface this time and CPU usage dropped back to normal after each inclusion, including the last one. Last time I used z-tool and the cpu usage stayed high, so in my case this is strictly related to z-tool.
                            #28
                            I added three locks recently using Z-Tool and encountered the high CPU issue each time. I found that simply opening the Z-Wave Controller Management page (Plugins->Z-Wave->Controller Management) returned things to sanity. Seems like that might explain your experience as well.
                            This on Hometroller S6 (Windows 7), running latest released versions.
                              #29
                              ​​​​​​I never tried that before. I have the same experience . Nice catch. Run on Linux however.
                              Len
                              Enabled Plug-Ins
                              2.0.54.0: BLBackup
                              2.0.40.0: BLLAN
                              30.0.0.36: RFXCOM
                              3.0.6.2: SDJ-Health
                              3.0.1.190: Z-Wave
                                #30
                                Found this thread, and it's exactly what I still experience!
                                Is nothing done with this bug?
                                Using Z-tool when adding, my server could increase the speed of the fan after a few minutes.
                                Even just open Z-tool on my Iphone and just do a "node connectivity", will after approximately two minutes raise the CPU usage in the same manner as adding a node.
                                I noticed that the CPU usage for the Z-wave plugin was around 30-50% and would stay there until I disabled/enabled the plugin.
                                Also checked the tip from post #28 and this also work.
                                It seems that the Z-tool opens a connection or something that does not closes down.
                                Using HS4 4.1.4 (tested from 4.1.3 to 4.1.5), Z-wave plugin 3.0.2.0
                                Windows 10 pro.
                                There are workaround for this problem, but I would be nice if the bug was taken care of.
                                Thanks!
