Originally posted by The Profit
View Post
Z-Tool causing high CPU issues
Len
Linux version: Linux homeseer Ubuntu 16.04 x86_64
Number of Devices: 633
Number of Events: 773
Enabled Plug-Ins
2.0.54.0: BLBackup
2.0.40.0: BLLAN
3.0.0.48: EasyTrigger
30.0.0.36: RFXCOM
3.0.6.2: SDJ-Health
3.0.0.87: weatherXML
3.0.1.190: Z-Wave
Originally posted by lveatch View Post
I repeated the same steps with the same results. I enabled zwave's Detailed Debug logging to .../Debug Logs which I am happy to provide.
Thank you
Sent from my iPad using TapatalkHS4 4.2.6.0 &HSTouch Designer 3.0.80
Plugin's:
Originally posted by The Profit View Post
That would be great! If possible, post them to this thread?
Thank you
Sent from my iPad using TapatalkLen
Enabled Plug-Ins
2.0.54.0: BLBackup
2.0.40.0: BLLAN
30.0.0.36: RFXCOM
3.0.6.2: SDJ-Health
3.0.1.190: Z-Wave
I have seen this reported in the past, but so far we are not able to re-create it here on any system. Is this on Windows only? Are any web pages open on nay system when you use Z-Tool? Does it only happen when add device, remove a device, both? Or any other Z-Wave function? What type of device are you adding, and does that matter?
Originally posted by rjh View PostI have seen this reported in the past, but so far we are not able to re-create it here on any system. Is this on Windows only? Are any web pages open on nay system when you use Z-Tool? Does it only happen when add device, remove a device, both? Or any other Z-Wave function? What type of device are you adding, and does that matter?HS 4.2.8.0: 2134 Devices 1252 Events
I have a Hometroller Pro and do not have any windows open, just HS3 running and the Homeseer Speaker window open. I personally have just experienced it when adding a z-wave device and so far it hasn’t happened with any other function. It does happen with either with Z-Tool or the HS Web UI, not just Z-Tool. It doesn’t seem to matter what type of device that I am adding, it has happened with HS light switches, dimmers and also Qubino devices.
Plugin's:
This happens for any z-wave device I add via z-tool+ via my android phone. I have attached screen captures of what occurs when removing a device. I ran two test. First test is where I clicked the remove device and aborted it after 10 prompts to start the exclusion process on the device. The second test is where I removed the device immediately. From the graph for test 2, you can see the z-wave mono cpu drop after the device was removed. However, there was a increase in z-wave cpu afterwards which persisted. During an add, I do not see this short drop in z-wave cpu as you can see from the graphs in my previous post.
I do not have this issue when using HS web interface (chrome on windows). This is the same two tests performing an add of the same z-wave device.
Len
Enabled Plug-Ins
2.0.54.0: BLBackup
2.0.40.0: BLLAN
30.0.0.36: RFXCOM
3.0.6.2: SDJ-Health
3.0.1.190: Z-Wave
What version Z-Wave plugin is this? Also, what type of Z-Wave interface? SmartStick+ or Z-Net?
I run HS on Linux (ubuntu server 16.04.5 LTS) on VMWare esxi 6.5. I do not have any HS web pages open, however, several HSTouch android tablets/phones. are connected 24x7.
Originally posted by rjh View PostWhat version Z-Wave plugin is this? Also, what type of Z-Wave interface? SmartStick+ or Z-Net?
I use a z-net connected via ethernet.
Z-NET V2 Configuration - Version 1.0.23
HS info:
Current Date/Time: 3/20/2019 12:19:40 PM
Linux version: Linux homeseer 4.4.0-141-generic #167-Ubuntu SMP Wed Dec 5 10:40:15 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux System Uptime: 24 Days 21 Hours 31 Minutes 36 Seconds
IP Address: 192.168.1.119
Number of Devices: 678
Number of Events: 798
Available Threads: 600
HSTouch Enabled: True
Event Threads: 99665
Event Trigger Eval Queue: 0
Device Exec Queue: 0
HSTouch Event Queue: 0
Email Send Queue: 0
Anti Virus Installed:
Enabled Plug-Ins
2.0.54.0: BLBackup
2.0.43.0: BLLAN
3.0.0.56: EasyTrigger
30.0.0.37: RFXCOM
3.0.6.7: SDJ-Health
3.0.0.91: weatherXML
3.0.1.249: Z-WaveLen
Enabled Plug-Ins
2.0.54.0: BLBackup
2.0.40.0: BLLAN
30.0.0.36: RFXCOM
3.0.6.2: SDJ-Health
3.0.1.190: Z-Wave
Originally posted by macromark View PostGuys - Rich is working on a big project now and won't be able to put eyes on this for a few months. If restarting the plug-in alleviates the problem, then at least that's a work-around you can use in the meantime.HS 4.2.8.0: 2134 Devices 1252 Events
Ok, on that note, I added the three devices using the web interface this time and CPU usage dropped back to normal after each inclusion, including the last one. Last time I used z-tool and the cpu usage stayed high, so in my case this is strictly related to z-tool.
This on Hometroller S6 (Windows 7), running latest released versions.
Originally posted by zwolfpack View Post
I added three locks recently using Z-Tool and encountered the high CPU issue each time. I found that simply opening the Z-Wave Controller Management page (Plugins->Z-Wave->Controller Management) returned things to sanity. Seems like that might explain your experience as well.
Len
Enabled Plug-Ins
2.0.54.0: BLBackup
2.0.40.0: BLLAN
30.0.0.36: RFXCOM
3.0.6.2: SDJ-Health
3.0.1.190: Z-Wave
Found this thread, and it's exactly what I still experience!
Is nothing done with this bug?
Using Z-tool when adding, my server could increase the speed of the fan after a few minutes.
Even just open Z-tool on my Iphone and just do a "node connectivity", will after approximately two minutes raise the CPU usage in the same manner as adding a node.
I noticed that the CPU usage for the Z-wave plugin was around 30-50% and would stay there until I disabled/enabled the plugin.
Also checked the tip from post #28 and this also work.
It seems that the Z-tool opens a connection or something that does not closes down.
Using HS4 4.1.4 (tested from 4.1.3 to 4.1.5), Z-wave plugin 3.0.2.0
Windows 10 pro.
There are workaround for this problem, but I would be nice if the bug was taken care of.
