Rich enhanced user level access a few releases ago with very little fanfare. If you didn't read the release notes, you probably weren't aware of this. Here's a quick little video showing up some of these cool new tweaks:
How to Set Up User-Level Access in HomeSeer
This is a sticky topic.
Thanks for posting this Mark. Will z-tool+ be updated at some point to work with local logins enabled? I would like to enable this in the near future as my boys' computer knowledge will likely exceed mine in the near future, but don't want to lose the z-tool functionality. [emoji3]
Al
Sent from my iPhone using TapatalkHS 4.2.8.0: 2134 Devices 1252 Events
Z-Wave 3.0.10.0: 133 Nodes on one Z-Net
Originally posted by sparkman View PostThanks for posting this Mark. Will z-tool+ be updated at some point to work with local logins enabled? I would like to enable this in the near future as my boys' computer knowledge will likely exceed mine in the near future, but don't want to lose the z-tool functionality. [emoji3]
Al
Hi Mark, I don't want them using ztool +, I want to use it, but my understanding is that it doesn't work if local logins is enabled. I want to give my boys access to certain devices in HS and restrict access to others so want to enable local logins.
Al
Originally posted by sparkman View PostHi Mark, I don't want them using ztool +, I want to use it, but my understanding is that it doesn't work if local logins is enabled. I want to give my boys access to certain devices in HS and restrict access to others so want to enable local logins.
Al
Seems like that is defeating the purpose of z-tool. I'd have to use the web interface first so that I don't have to use the web interface for the zwave plugin [emoji1]. How about an option in z-tool that allows you to configure if you want it to prompt you for login credentials?
Cheers
Al
PS I could argue that most people should be running with local logins enabled as security by obscurity is really not good enough these days... [emoji12]
Originally posted by sparkman View PostSeems like that is defeating the purpose of z-tool. I'd have to use the web interface first so that I don't have to use the web interface for the zwave plugin [emoji1]. How about an option in z-tool that allows you to configure if you want it to prompt you for login credentials?
Cheers
Al
User access not working in HS3Touch
Mark
I have edited many many devices to create a much smaller list of devices for my wife to access. When I log in as her from the Web UI, either locally or externally via my own domain the user access settings are honoured correctly.
When I log in using her account from HS3Touch externally using my own domain the user controls are ignored and she can still see all the devices that I removed access for. Haven't tried internally yet as not at home
Win 10 Pro
HS3 .206
HSTouch Server .75
Her account is of the type "Normal" with Event access but no access to Counters/Timers or Logs
I am probably missing something obvious
Cheers
Jamescheeryfool
Originally posted by macromark View PostIf everybody enabled local logins, this would be a no-brainer and we'd simply force a login with Z-Tool+. However, very few opt for that and for good reason. If a thief is logging into your system locally, he's probably already in your house, in which case... you've got bigger problems than unauthorized HS access!). I'm not worried about a thief breaking into my house that way. There are enough rocks in my yard that it's easy for any one to come in that wants to come in. However, I'm worried about my kids, wife or house guests accidentally doing something to my HA system that they shouldn't be doing and I'm also worried about some hacker group somewhere launching an attack on HS systems at some point in time just to prove that they can and maybe unlocking all doors and turning of all thermostats in the middle of winter. From my perspective the latter is a matter of when, not if, as the number of IoT and connected homes grows.
IMHO a strong security framework will be a must if HS wants to stay a leader in the HA space. To me this means that security must be able to be seamlessly applied without having to turn it off to allow some functionality to work. Hardware devices such as the z-net should be password protected, the web server should use a current version of SSL, etc, etc.
Cheers
AlHS 4.2.8.0: 2134 Devices 1252 Events
Originally posted by sparkman View Postthe web server should use a current version of SSLcheeryfool
Originally posted by mwaite View PostI agree. The Z-tool should have the same configuration settings found in HSTouch client. Once credentials are entered, they can be remembered for seamless logon as required.
I think the real risk is that if someone launches z-tool and select add or delete, then someone else turns on a light switch, z-tool might pick it up to add or delete.HS4Pro Running on a Raspberry Pi4
67 Z-Wave Nodes, 111 Events, 422 Devices
Z-Wave, UPB, WiFi
Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
Originally posted by rmasonjr View PostI think the real risk is that if someone launches z-tool and select add or delete, then someone else turns on a light switch, z-tool might pick it up to add or delete.
Again though... what's the likelyhood that someone would go to all this trouble to mess up someone's network? What would be the end-game? You can't control any devices this way... you can't unlock a lock with Z-Tool+!
I recently installed a Hometroller Zee S2 in a 40 person ski house. I need backup admins and for training purposes I would like tech savvy people to have read-only access so they could view events and all settings without being able to change anything. Once they're familiar I can allow them full access. Is there a way to give read only access to the entire system?
