AK ControlByWeb plugin - Ethernet and Web I/O
This is a sticky topic.
    Ethernet and Wi-Fi I/O Products
    Click image for larger version  Name:	image.png Views:	0 Size:	51.5 KB ID:	1655754​​ Click image for larger version  Name:	image.png Views:	0 Size:	134.3 KB ID:	1655755
    Click image for larger version  Name:	image.png Views:	0 Size:	275.3 KB ID:	1655756​​ Click image for larger version  Name:	image.png Views:	0 Size:	22.3 KB ID:	1655753
    Supported complete product line: X-300, X-310, X-320, X-332, etc, X400 Line, X600, SmartStorm Irrigation Controller, etc.
    Note: X-320M (Web-Enabled Weather Station) is supported in AKWeather plugin
    Try before you buy. For most devices online test URLs are available. If you want to test the plugin with the test device, please ask me for the URL.
    Click image for larger version  Name:	image.png Views:	0 Size:	85.5 KB ID:	1655757
    Click image for larger version  Name:	image.png Views:	0 Size:	145.3 KB ID:	1655758
    Click image for larger version  Name:	image.png Views:	0 Size:	168.7 KB ID:	1655759
      Configuration
      When the plugin starts - the new device is added automatically.
      To add more devices - flick "Add new device" switch and click Save.
      1. Go to device settings (or plugin settings) and select ControlByWeb type (i.e. X400, X600).
      Note - current temporary device will be deleted, new root of selected type will be created.
      2. Go to device settings (or plugin settings) and enter the device URL - the HS devices will be added for each digital / analog input, relay, thermocouple, onewire, etc.
      3. For devices with default names (i.e. "relay1") the type is recognised automatically and proper HS device is created.
      For user renamed devices user must select the device type in the Settings screen.
        Ver 4.0.0.5 - Added X400
          Very interesting. Will have to look into these devices, may have some uses for them. Thanks for the great plugins!
            I just realised that for X400 I only implemented current status display, no control yet. Will add later.
              Ver 4.0.0.6 - Added X300 Thermostat
                Ver 4.0.0.8 - pretty much final release
                - Added control functions X300, X400
                - Added WebRelay
                - Implemented adding new devices
                  Ver 4.0.0.11 - Added X-310, X-320, X-332
                    Ver 4.0.0.12 - Added SmartStorm Irrigation Controller
                    Click image for larger version  Name:	smartstorm-front-large.png Views:	0 Size:	251.8 KB ID:	1514843 Click image for larger version  Name:	2021-12-17 (2).png Views:	0 Size:	37.4 KB ID:	1514844
                    Click image for larger version  Name:	SmartStorm.png Views:	0 Size:	192.6 KB ID:	1514842
                      Ver 4.0.0.14 - Added XW110, XW111, XW112, X401, X405, X406, X408
                        Ver 4.0.0.16 - Added X-317. Now complete ControlByWeb line is supported
                          Having a bit of trouble adding a device. When I attempt to add a new device I just see the spinning circle and never get the option to add. Any thoughts on how to get past this?
                            I started a new thread for you https://forums.homeseer.com/forum/hs...dding-a-device
                              Ver 4.0.5.11 - Fixed selecting type of unrecognised values. Also if you enable "Show Advanced Settings​" you can change already selected types:
