AK NetCam | AK Weather | AK Web I/O | AK Bond | NeoSmart Blinds | Arylic Linkplay | AK SwichBot | EspHome~~ | AK_Modbus |
EnphaseEnvoy | AK IKEA | ControlByWeb | AK_Shelly~~~ | AK Remootio | AK Traccar | AK AndroidTV | Konnected | AK_YoLink |
AK PumpFuse | AK GoogleCast | GoogleCalendar | AK Sonoff | SmartDevice | HeatmiserNeo | HomeAssistant | Link&Link | AK_Yamaha |
AKWebIO - Plugin for controlling IP/IoT/WEB/USB relay and input boards and controllers (i.e. Denkovi, Kincony, KMtronic, Teracom, etc) Flexible plugin architecture allows the plugin author to easily add device support. Please post your requirements in Feature Request. |
ControlByWeb devices have dedicated AKControlByWeb plugin | |
iBoot Web Power Switch |
Digital Loggers DLI Web Pro Switch |
Robot Electronics (Devantech) | ETH002, ETH008-B - 2 / 8 relay outputs (16 Amp) ETH484-B - 4 ethernet relay, 8 DI, 8 DO, 4 AI ETH8020-B - 20 ethernet relay, 8 Analog Inputs |
KinCony - 2/4/8/16 CHANNEL ETHERNET WIFI RELAY MODULE – KC868-H2/4/8/16B | More info https://forums.homeseer.com/forum/hs...-kc868-h2-4-8b Warning: "In short, you might get decent hardware, but don't expect anything resembling customer service" |
Teracom - Remote IO module TCW122B-CM Remote IO module for environmental monitoring and control, designed to work in Ethernet networks. |
Two relays, two analog voltages and two digital inputs. Two 1-Wire temperature/humidity sensors. |
Teracom - Ethernet digital IO module TCW181B-CM | 8-channel Ethernet relays (up to 3 A), one digital input |
Teracom - Ethernet data logger TCW220 | 2 relays, 2 digital “dry contact” inputs, 2 analog inputs, 8 1-Wire sensors |
Teracom - Ethernet IO module TCW241 | 4 high current relays, 4 digital “dry contact” inputs, 4 analog inputs 60VDC, 8 1-Wire sensors |
KMTronic - LAN Ethernet IP 2/4/8 channels WEB/UDP Relay boards | |
Kmtronic DS18B20 Temperatue Monitor 4/8 channels |
dingtian-tech 2/4/8/16 Relay boards | https://forums.homeseer.com/forum/hs...8-relay-boards |
Denkovi - WiFi 16 Relay Module, TCP/IP, UDP, Virtual Serial Port | Wi-Fi controlled relay board with 16 channels up to 10A / 250VAC each. |
Denkovi - DAEnetIP4 - SNMP Ethernet controller with 34 digital/analog I/O | 16 digital outputs, 8 digital inputs (16 bit counters), 8 x 10 bit analog inputs, 2 x 10 bit PWM channels |
Denkovi - smartDEN Maxi I/O Relay Module | 8 digital inputs, 4 analog inputs, 4 temperature inputs, 8 SPDT relays, 2 analog outputs |
Denkovi - smartDEN Opener | IoT smart Garage Door Controller with Wi-Fi, Relays, I/O |
