Post your ideas here
Feature Request
This is a sticky topic.
Originally posted by Iacontrol View PostAny some help
Denkovi Controller DAENETIP4 does work with the plugin AK Webio?
some one can tell me the Server URL , Username and password.
thank for your help
https://forums.homeseer.com/forum/hs...d-input-boards
Server URL , Username and password - that's how your system is setup, i.e. your DAEnetIP4 IP address and port (i.e. 151.252.192.162:10011).
Default port is 80, in this case you don't need to include the port in the URL.
Some devices don't require the username, only password - which you set in the device config UI, from the user manual
Would this PI work with the Kincony KC868-COLB? If yes, would it work with more than one of them? https://www.kincony.com/programmable...ller-colb.html
How about the Dingtian 16 and 32 relay boards? https://www.dingtian-tech.com/en_us/...html?tab=relay
Originally posted by doomngloom View PostWould this PI work with the Kincony KC868-COLB? If yes, would it work with more than one of them? https://www.kincony.com/programmable...ller-colb.html
Denkovi relays should be easier for me - as they have online test devices. Also https://www.teracomsystems.com/ethernet/.
[EDIT]
And yes, the number of devices is unlimited.
Originally posted by alexbk66 View Post
I haven't added more than 8 in/out boards (except for KinCony - KC868-H16B) - but it should be quite trivial if you are willing to test, since I don't own them.
[EDIT]
- Likes 1
alexbk66 I got the KC868-COLB in today. Ill be out until Sunday but let me know what kinds of testing you would like me to do.
As as a test i added a device as the H16B to see if it works but i get the below errors. i've removed my ip address but kept the port i have configured in the COLB
Code:[3527] 'Kincony 16': Exchange send 'RELAY-GET_INPUT-255' 3/24/2023 12:44:41 PM AK WebIO Warning System.Net.Sockets.SocketException (0x80004005): ### System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress) at: System.Net.Sockets.Socket.Connect(EndPoint remoteEP) at: System.Net.Sockets.TcpClient.Connect(IPEndPoint remoteEP) at: PluginLib.TcpClientEx.Exchange(Byte[] bytes, Int32 max_repl) at: PluginLib.TcpClientEx.Exchange(String data, Int32 max_repl) 3/24/2023 12:44:41 PM AK WebIO Error [3527] 'Kincony 16': Exchange(RELAY-STATE-255): A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond X.X.X.X:5555
Originally posted by doomngloom View Postalexbk66 I got the KC868-COLB in today. Ill be out until Sunday but let me know what kinds of testing you would like me to do.
https://forums.homeseer.com/forum/hs...ony-kc868-colb
Would this plug-in work with the Digital Loggers "90-240V 1-U Smart Switch (220)" or the "Web Controlled DIN Relay III"? I've got both along with a DLI Pro switch and would like to use your plugin to control all of them.
BTW, I've been using your ControlByWeb plugin for a while now and it's been terrific!
Originally posted by PJL660 View PostWould this plug-in work with the Digital Loggers "90-240V 1-U Smart Switch (220)" or the "Web Controlled DIN Relay III"? I've got both along with a DLI Pro switch and would like to use your plugin to control all of them.
For the other two I need to check the API. Are they correct devices:
https://www.digital-loggers.com/220faqs.html
https://www.digital-loggers.com/din3faqs.html
