Denkovi - smartDEN Maxi I/O Relay Module
    Hi,
    Now I have bought 2 pieces Denkovi - smartDEN Maxi I/O Relay Module, al is working god, But the 2 analog outputs would like to check some led lampport with the 0-10v outputs.
    Skapade one Event but where do you enter the light strength you want? stands missing nothing else.
    Best Regards Jens
    Hi Jens, thanks for reporting.
    It looks like something was broken in HS code as it was working before. The control range for the analog outputs doesn't have the "End" value.
    I fixed in ver 4.0.5.3 (in BETA until released by HST). You will need to delete and re-create the devices for the control range to be set properly.
    Alternatively you can just set the "End" to 1023 yourself:
    ​Also, in the event action value selection has increments of 4 for some reason, I opened a ticket here https://github.com/HomeSeer/Plugin-SDK/issues/343
      Note: to install BETA please enable "Show Beta Plugins" on Plugins => Add page.
        Strange when I put in 1023 where you described, I only get 1023 where you get 4 8 12, , see picture
          The attached picture is same as mine?
            Sorry new pictures
              Now it works, I didn't delete the IP relay but the program itself before...
                Do you have the range in the event configuration?
                  Yes but it jumps 4 steps between each value 4.8.12, and so on
                    Yes, that's what I said in post # 2
