few weeks ago I noticed that the temperatures are not displaying correctly from your software, the ds18 is working and showing correct temps. I disconnected the power to unit to see if it would reset, I tried to poll, just stays at 32 degrees, also the dates stay at 4/1/2023.
KMT DS18B20 Temperatures not displaying correctly
I checked my code, it looks like I support only 4 sensors because I tested with https://www.kmtronic.com/index.php?r...product_id=106, but your device is https://www.kmtronic.com/index.php?r...product_id=108 "Support up to 8 DS18B20 temperature sensors".
So I guess it couldn't work anyways. I need to add your device.
Did you create a new device for the 8 channels DS1820?
And to troubleshoot the problem - I need more info. I.e.
- screenshots of device config screens
- log? Please enable Log for each device, restart the plugin, filter HS log by plugin (FROM FILTER) and EXPORT to file.
- also output from Tools => Help may be useful
Originally posted by Joe P View Postwhy don't temps match? from the CTRL and the LINK
The device is 4 channels, but you have 8 temperatures. What is it supposed to be?
If you have only 4 - can you delete all child devices (keep the root) - and restart the plugin.
If you have 8 - you need to recreate the device completely and select 8CH device.
BTW, I noticed in the KMT plugin there's children status overview page, I also added children to MyDevices page, see https://forums.homeseer.com/forum/hs...64#post1612664
