Using Arduino Uno as board in IDE 1.8.9
When compiling there is an error about low memory:
IDE error
"Sketch uses 25340 bytes (78%) of program storage space. Maximum is 32256 bytes.
Global variables use 1923 bytes (93%) of dynamic memory, leaving 125 bytes for local variables. Maximum is 2048 bytes.
Low memory available, stability problems may occur."
in HS log:
8/8/2020 7:38:51 PM Arduino-4 Error Error = Exception in RecievedData4 : Index was outside the bounds of the array.
8/8/2020 7:38:51 PM Arduino-4 Error Error = Exception in RecievedData3 : Index was outside the bounds of the array.
8/8/2020 7:38:51 PM Arduino-4 Error Error = Exception in TimerReset1 : Index was outside the bounds of the array.
8/8/2020 7:38:51 PM Arduino-4 Error Error = Exception in RecievedData1 : Index was outside the bounds of the array.
8/8/2020 7:38:51 PM Arduino-4 Info Data Received: ?@
8/8/2020 7:38:45 PM Arduino-4 Info Sent to IP:192.168.1.67 Port No:8900 = 1 r ,Reset
8/8/2020 7:38:45 PM Arduino-4 Info Sent to IP:192.168.1.67 Port No:8900 = 1 C ,Connect
8/8/2020 7:38:45 PM Arduino-4 Info Connecting Board No:1 at ip address 192.168.1.67 Port No:8900
8/8/2020 7:38:41 PM Arduino-4 Info Debug logging Enabled
ArduinoDebug (2).txt
IDE error
in HS log:
